That's one of his problems, he uses sygic, so RR at present does not get a GPS feed.
As he says he will need to use a COM splitter (Xport), However he wants to simulate data going to both sygic and RR on his desktop (at least that's the way I read it).
GPS Simulation.
1. You could use GPSGate, it's also a comsplitter but I believe it also does simulation. (but it is not free like xport)
2. you could get a Virtual port program (again they are not free), feed it a NMEA log.
3. Have a program on a second computer feed info from a NMEA log to itt's comport, join the two PC's together wit a NULL modem cable and then run xport.
With both 2 and 3 you will need to of obtained a NMEA log, if you need help with this I have a program that will do this.
Also with 2 and 3 you will need a program to send the NMEA log to a com port, again I have a program that can do this.
LinkBack URL
About LinkBacks
