Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
Thread: Speed Limit / Speed Zone Plugin RELEASED
  1. #31
    Dec 2007
    Thunder, forgive me, i am not getting the clear picture of how this works.. So, every time speed limit changes on the road, you have to set new speed limit in RR explicitly?
  2. #32
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by brandensin View Post
    You can do that or set speed zones which will change it automatically as long as you pass through that zones perimeter of 30 feet.
    It is not really meant to monitor all of the changing road speeds. You can have up to 10 speed zones. These zones can be set for school zone where the speeds change down to 15mpg from 25 sometimes. Or other zones.
    A use for this would be if you borrow your car out to someone. If your speed limit is set to 75mph (because you dont want them going that fast) then it will remind them to slow down and thank them when they do.
    Of course if you dont want to here it, you can set a speed zone to 100mph and it wont even bother you again, unless you go over 100.
    Also this will announce when you are approaching your home and run an RR command once you arrive. This is usefull for internet updates or what ever you want to happen when you get home. It does the same thing when you pass through a zone, it will run a command for that corresponding zone.
    So if you want your computer to update at starbucks wifi, then you could have it run a command to do so.
    New Age Garmin - Skin for RR
  3. #33
    Aug 2006
    West Allis, WI
    Quote Originally Posted by Enforcer View Post
    Bl00dy 'ell everyone's having a parade.
    And the weathers terrible.
    Not to rain on your parade, but the weather is beautiful here
  4. #34
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Quote Originally Posted by treetop777 View Post
    You didn't read the whole thread did you!
    ok i'll hold m hands up .. no I didn;'t read the whole thread, but now I wish I had, I feel ever so silly ...
    and the weather is beautiful over here too, for a change ... not no parades around that I could see ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  5. #35
    Aug 2006
    West Allis, WI
    Release V4.0 with by Skin, Blades Edge....
    Will release this alone later on
  6. #36
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    For log playback, get my compass (off the XPort page). Once you set the log path to where all your logs are, start it up and open the config. Just click on a log file and it plays through xport.
  7. #37
    Aug 2006
    West Allis, WI
    OK, after realizing how much of a resource hog this little program was. I decided it needs attention. So it got it.
    It used to case my CPU usage to jump from 10-20 % up to over 75%. Now it only increases by about 10%. THis program is constantly working in the background so it is hard to create something that does not use as much resources. But all in all, it is a lot better now.
  8. #38
    Aug 2006
    West Allis, WI
    Just not released quite yet...
  9. #39
    Aug 2006
    West Allis, WI
    v4.0 released on it's own. Uses much less resources than previous version. Works great. Instructions are quite extensive so please read them carefully.
    Thanks,
  10. #40
    Aug 2006
    West Allis, WI
    An example skin from my New Age 2 Garmin Style skin is included now 9/15 and should help you with your setup.
  1. Replies: 36
    Last Post: 07-05-2006, 11:10 AM
  2. Got caught by a money generating speed cam...
    By Chris31 in forum Off Topic
    Last Post: 10-05-2005, 07:31 PM
  3. Replies: 2
    Last Post: 08-31-2005, 07:01 PM
  4. Speed Limit
    By tolisn in forum FreeDrive
    Last Post: 08-17-2005, 07:11 AM
