Page 6 of 6 FirstFirst 123456
Results 51 to 55 of 55
Thread: Speed Limit / Speed Zone Plugin RELEASED
  1. #51
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    OK release will more than likely happen this week...
    The code is done just needs testing..
    New Age Garmin - Skin for RR
  2. #52
    Aug 2006
    West Allis, WI
    12/18/2008 New Version included with my New Age Garmin Skin
    -20 Speed zones (was 10)
    -Detects your speed zone according to the direction you are driving
    -Better detection of coordinates
    -Fixed bug with not reporting current speed zone speed limit and current speed zone to Road Runner
    DOWNLOAD NAV29.ZIP from my new age skin thread
  3. #53
    Raw Wave lostreception's Avatar
    NY
    also you might want to add in some fluff factor if u havent already to the direction for example ranges of direction one being 135 degrees and another being only 60 or a very broad one like 180 degrees play on either side
    plus dont forget the whole if your at 359 degrees you have to include down to 299 and up to 89 if ur doing 180 patterns etc. but im sure u added that. when i was going to make an app like this i envisioned a button i would press which would grab my current heading and lat lon and be able to select the sweep range of the direction 60-90-135-180 etc and also maybe even subtract in feet in the reverse direction if i hit the button too late. if your up to it that would kick ***. glad u like the heading idea and implemented it so quickly too nice work
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  4. #54
    Aug 2006
    West Allis, WI
    I add a "fluff" factor of only 2 degrees. After testing I relized this is not nearly enough. I think 30 degrees should be fine.
  5. #55
    Aug 2006
    West Allis, WI
    Pluggin with update for 20 degree "fluff factor" (give or take 20 dgrees from setpoint) will be released after test run.
    Code is complete... And looks pretty good now.
  1. Replies: 36
    Last Post: 07-05-2006, 11:10 AM
  2. Got caught by a money generating speed cam...
    By Chris31 in forum Off Topic
    Last Post: 10-05-2005, 07:31 PM
  3. Replies: 2
    Last Post: 08-31-2005, 07:01 PM
  4. Speed Limit
    By tolisn in forum FreeDrive
    Last Post: 08-17-2005, 07:11 AM
