Results 1 to 2 of 2
Thread: MovieTimes Nav for Garmin and iGuidance
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Thumbs up MovieTimes Nav for Garmin and iGuidance
    This script will replace the one that comes with SonicXtacy's movie times plug in. Make a back up of the movietimesnav.exe file by renaming it to movietimesnavBU.exe then copy the movietimesnav.exe file from this archive to the movietimes directory in your RR folder.
    When you press the navigate button from with in the movie times screen this will convert the coordinates from movietimes and make it useable with garmin mobile pc, then will enter all data automatically.
    This will run RR command "GARMIN" to launch garmin so you will need to add the following lines to your exectbl.ini
    "GARMIN","GPS"
    "IGUIDANCE","GPS"
    IF you use elcosmenu for OSK or other things with these you will have to modify the command to your liking. But the RR command that is called from the script is either "GARMIN" or "IGUIDANCE" so the string for these commands can be changed to what ever.
    My skin will be released soon, and you will be able to get examples from it if needed.
    Attached Files Attached Files
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    [MEDIA]http://www.youtube.com/watch?v=qiJktQgMtD0[/MEDIA]
    YouTUBE preview 19 Sep 2008
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  3. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  4. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  5. How to get iGuidance to nav like mapquest?
    By UnsanePyro in forum GPS
    Last Post: 11-27-2005, 03:37 PM
