All plugins should be in a subfolder in Road Runner\Plugins, makes it easy for everyone.
I totally, and 100% agree with both points.
1) a SET folder for plugins:
The Road Runner is getting more and more cluttered up with all of the plugins (And a big surge of them in the past 6 months or so)
On my system, I have 16 folders in the Road Runner folder for plugins, as well as 36 (THIRTY SIX!) dll's in the root Road Runner folder. It is just out of control!!!
I also think it should be:
Road Runner\Plugins
and inside that sub folders (\RRMedia,\MovieTimes ect...), as many plugins and packages, scripts ect have many files.
I can put the DLL's in a Plugins folder, as Enforcer mentioned, RR does not care where they are if they are registered.
But I can NOT move the 16 folders, MovieTimes, Gas, and so forth, as they would no longer work.
2) An entry in the rr.ini to point to whatever folder, such as:
PluginsLocation=C:\Program Files\Road Runner\Plugins
This would still let people choose where they are located, while still allowing a standard "Root" location.
My Fiero Build Thread
OK, resurrected this.
I now have another suggestion.
All plugins should have an indicator that has the same name as the plugin, so that other plugins can tell if they are running or not.
I think that is a great idea.
#1 A plugin with issues with another plugin would allow some error checking and maybe react diffently if the other one causing the problem is running.
#2 If someone makes a plugin that could use info that another plugin already populates a label then you could just grab that, instead of doubling the work the the other plugin did in the fist place, which could help to keep things efficient.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
Also if I know RRMedia is running then RRUpd8 on a successful copy of new files to RR's Musicpath can get RRMedia to reread the music. (I assume their is a command for this, I did ask in the rrmedia thread but you nicely ignored my questions)
It has already.(well to the plugins standardisation sticky in the plugin section)
