Results 1 to 6 of 6
Thread: CD Rip troubleshooting help needed
    Constant Bitrate overlander's Avatar
    Feb 2008
    I have the latest build of RR, and have followed the steps to integrate CDRip as I understand them. I can get CDRip skin to load from DFX without errors, and it closes as well, but it will not show any tracks on installed audio cd's, no matter what I try. Not sure how to diagnose. I have the exectbl.ini as indicated in RR root path, and I have run the dll registery bat in the cdrip folder. What line of code am I missing, and where is it?
    RR has no problem playing tracks on my cd's on my USB cdrom.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If I rememeber correctly you need to fill in some of the information first before it will display the tracks.
    Not sure whether it was Album, Artist or genre.
    Feb 2008
    I actually had it running before, but then my moboard took a dump, and had to replace it with a different one, so I wiped the drive and reloaded OS and RR. Before it would automatically populate with generic track numbers after loading cdrip, then it would look up freedb tag info after hitting the cddb button. I can't even get it to load generic track numbers now. hmmm. stumped.
    Apr 2007
    I seem to have the same problem. Ever find a solution?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It could be the Adaptec wnaspi32.dll is not working with newer versions of XP.
    I had to go hunt for a newer (modified) version
    I got it from here and it seemed to work for me. (Obviously your milage may vary)
    Apr 2007
    Thanks Enforcer. I'll try that out.
  1. Removing Stock CD player, Installing Aftermarket
    By workhard20 in forum Car Audio
    Last Post: 02-19-2009, 02:19 AM
  2. CD Rip Release link is bad
    By blaforce in forum RR Bug Tracker
    Last Post: 01-10-2007, 07:49 AM
  3. FOR SALE - ICE - Clarion Top End Mini Disc & CD changer
    By Paul_GPvR in forum Classified Archive
    Last Post: 01-21-2005, 05:28 AM
  4. Aiwa vs. Pionner cd player
    By mp3stealth in forum General Hardware Discussion
    Last Post: 09-03-2003, 05:34 PM
