Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 97
Thread: Road Camera HD - Backup camera viewer and Mobile DVR plugin
  1. #21
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    evrything you do is up to you , i'll follow what your doing and input where i can.
    as for the plug on a russian forum , i'm yet to find it but it was this fourm i found it.
    http://www.pccar.ru/
  2. #22
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    wow that site seams to be exact copy of mp3car forum. do you remeber which section did u look at?
    Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
  3. #23
    Low Bitrate SoulR's Avatar
    Aug 2007
    subscribed,
    Very interesting project,
  4. #24
    Jun 2007
    RCHD 0.1.4.2 was released ... try it out (download from the first post)
    basic change log: added configurable sounds to start/stop video recording and photo snapshot
    detailed change log:
    0.2.4.2
    New Features
    -Added audio support for Recording buttons
    you can sustomoize sounds in RCHD.ini.
    Supported functions include Start Video/ Stop Video/ Take Photo Snapshot
    THe audio is limited to 5 sec and ten will be cut off. If you need more time then let me know
    Known Issues:
    -Audio relys on DirectX audio playback and DX has a memory leak for this function so we have to
    cut off audio after some time to avid memory leaks. I didnt see to much of them but ffShow was
    started each time i request audio and it was only closed when the app is closed, The car computing
    assumes the app will be open all the time so i did dirty garbadge collecting afther 5 sec (we just close all audio and
    release memory)
    If you dont like to be at risk you can simply disable audio in config file and you will not be at reask of memory leaks
    I know about an issue ;-) and if i find better way to handle sounds I will fix the problem
  5. #25
    Jun 2007
    ok, support for RR GPS has been added (build is not posted yet)
    Now I think it would be reasonable to add RR overly before i go and add much more advanced functionality
  6. #26
    Jun 2007
    ok i hvae played around with fotoshop and here is something that would look like w/ RR skin. I did not do the skin as i have no idea how to build it from scratch yet,... but I hope I learn that
    PS: sorry for nigh camera snapshot... i work at night on personal projects ;-)
  7. #27
    Jun 2007
    I got stuck with doing overly... I can run my app from the button, but the skin doesnt load
    Also how can I accept comands from the RR skin to be parsed in my app?
    Hope some one help me out with skins
  8. #28
    Aug 2004
    Germany
    You can send commands to your app with SENDMSG.
    Code:
    B01,000,000,100,30,"SENDMSG;<windowtitle>;<command>"
    When you're going to support SENDMSG it'd be cool if the buttons in the RCHD-GUI could be hidden, as they're not needed.
  9. #29
    Jun 2007
    Ok thats how I send message from RR GUI to my APP,
    but how to I listen to it in my VB application? Is that the same sendmessage as linux socket api? Also how can I send status message back to RR?
  10. #30
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    After .net install and reboot, this is the error i'm getting when trying to install the program:
  1. Backup camera question
    By winNvegas in forum StreetDeck
    Last Post: 08-28-2008, 12:27 PM
