How do I change the resolution of my camera in Road Camera? I open amcap and set it to 640x480 and it looks good but in Road Camera it looks like 320x240 and very blurry.
Printable View
if you are using original V1 the video panel size is 320x240 (i think) in some cams thats other then Logitech resolution will be automatically "smoothed", and if you happan to have logitech then it will be squared pixlized image. As to changing resolution V1 doesnt have support for Video Pin so you realy need to use AMCap for that.
In V2 resolution will be smootthed automatically by DS filter all streams look good and Video PIN config is alredy added. But I'm still strugling to make DS work the way i need it :( Maybe some one knows DirectShow better then me? There are samples in C# but I use VB and since DS is not .Net structured conversion is not working very well :(
Just tried RRHDCam, I think it's your v1 0.300, so far so good...
Using Logitech Quickcam 9000.
Good job man, looking forward to updates, sorry can't really help...
pcpete: tnx
quick update:I have added suport of hybernation and standby modes in V2..
Will post build version for testings soon.
ok we are getting better with V2 release.
I have aded some new features so that our V2 would look like an app more or less.
Build preview is available at the first post's download section.
New Things:
- Select Video Source
- Show properties Pin of the video device (Thats real new ;-)
- mirror
- text overlie
- list all installed codecs
It still not as good as V1 but this girl should deliver better perforamance then V1... and hopefully it works on Vista (didn't try it yet as i still didnt install vista on anything)
Next steps:
1. Add video recording
2. Add still image capturing
3. Add sendcomand interface for RR integration (need help here)
4. Add buffer recording
5. Add suport for gyro (as shock sensor)
6. Add multi camera support
7. Add object recobnition logic
8. Add GPS loging
9. Add ability to replay files and see gps coordinates at the same time on the map!
10. screw everyone and go on vocation :lol:
Any way if you see any bugs, let me know asap and we will use some raid :)
will try this very soon
continu the good work
Sounds great :). Thanks for your hard work tempgp.
lol
it don't seem to work for me??
i installed V1
when it start i see the window but all button are black and the rest if the screen is also black
and i tried to register the dll but can't find it ?? only the one with the prefix
installed V2 and can see the image no problem
