Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
Thread: RRJTFE: Jump To File Extension Plugin (beta)
  1. #31
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Sal R. View Post
    T
    On the Queue List screen, there is a button that clears your queue.
    Hmm, it doesn't seem to be working for me. Maybe I'm just being an idiot. I'll play with it some more.
  2. #32
    Nov 2008
    If anyone is interested I made a skin for this plugin for the DigitalFX 4.0 skin. It pretty much has all the same buttons and functions except it matches the DFX skin. Here is what it looks like...
  3. #33
    Nov 2008
    I've been messing around with this plugin and I noticed that with v.097 the jump to file in winamp can only display artist and track title info, but v.099 can also display album info. Unfortunately v.099 doesn't work. Any chance on getting v.099 working with this plugin, or what it might take to make it work? Thanks....
  4. #34
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by Cdeldridge View Post
    I had trouble w/ getting that version to work w/ the plugin. Specifically, its queueing functions. The queue window seems to be handled differently, and I couldn't get the plugin to interface with the controls.
    What you can do, however, go to WA's Preferences >> Titles >> Advanced Title Formatting
    In the "Advanced title display format:" field, enter:
    [%artist% - %album% - ]$if2(%title%,$filepart(%filename%))
    Close and restart WA and that should show Artist, Album, Title Info that is available in the JTFE window.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  5. #35
    Nov 2008
    Thanks for the info, but I already have it setup that way. The problem is, is that the jump to file formatting is different and with v.097 it does not pull the advanced title formatting into the JTFE window, but it seems to with v.099 (at least for me). Weird huh? Here is the options of the jump to file, formatting (note that there are no formatting options for album):
  6. #36
    Aug 2006
    Sun Diego
    I'm using winamp v5.13 w/ JTFE v0.97.7 (Build 49) and the playlist formating works and carries over to the JTFE plugin.
    As far as I can tell, the JTFE formatting is for post playlist formatting for queueing information.
    If you didn't know already, you have to reload the playlist for the playlist formatting to take place.
  7. #37
    Nov 2008
    Thanks for the help. I'll keep messing with it to see if I can get it to display properly.
  8. #38
    Sep 2003
    Thousand Oak, Ca
    great addition, can the window be controlled with a slider? I tried adding a playlist slider and it didn't work.
    thanks
    mike
  9. #39
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    how do you mean PL slider , the slider that scrolls the list , yes it dose work, or ilist flick slide
  10. #40
    Aug 2006
    Sun Diego
    Quote Originally Posted by mskrzat View Post
    thanks
    mike
    You need a CL slider.
  1. Replies: 119
    Last Post: 12-25-2007, 03:20 PM
  2. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. jump to winamp plugin?
    By metlok in forum Software & Software Development
    Last Post: 05-12-2002, 11:24 PM
