Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
Thread: RRJTFE: Jump To File Extension Plugin (beta)
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    This plugin is inspired by DJik's awesome, but no longer supported, JTFE plugin for realtime playlist searching and queueing. It is completely recoded from the ground up since I couldn't get through his source code.
    Release: 11/07/2008 Beta
    Included Features:
    - Fully skinnable using RR's current standards (Carwings sample skin included)
    - Direct control of Winamp v5.13 Jump To File plugin, which includes:
    - - Queueing tracks
    - - Playlist searching
    - - Jump To File
    - - Queue List Management
    Update: 11/07/2008
    All the functions of the Winamp JTF plugin are now useable thru this extension plugin. You must use the JTF version (v0.97.7) attached on this post for all the functions to work correctly.
    Those using v0.96fg and the latest version v0.99 will be very buggy when trying to use this plugins queueing functions.
    INSTRUCTIONS
    1 - Unzip & copy RRJTFE folder to your Road Runner directory
    i.e. > Road Runner\Plugins\RRJTFE
    2 - Copy RRJTFE\skins\*.* files into your preferred skin folder
    3 - Create a button w/ "RRJTFE" button code
    i.e. > BXX,...,"RRJTFE",""
    4 - Add the following line to PLUGINS.txt or MENU.skin
    X,RRJTFE
    5 - Add the following line to your ExecTBL.ini
    "ONSONGSTART","rrjtfe_onsongstart",RRJTFE.skin
    6 - Register RRJTFE.dll by double-clicking "Register.bat"
    REQUIRED SKINS
    RRJTFE.skin
    OSK.skin
    BUTTON COMMANDS
    "rrjtfe" - Loads RRJTFE.skin
    "rrjtfe_playlist" - Shows playlist window
    "rrjtfe_jumptofile" - Immediately plays selected track from playlist window
    "rrjtfe_queuefile" - Adds selected track to queue in sequential order
    "rrjtfe_search" - opens OSK.skin for search criteria
    "rrjtfe_clbox" - Clears search results and reloads all playlist contents
    "rrjtfe_queuelist" - Show queue list window
    "rrjtfe_removequeuefile" - Removes selected track from the queue
    "rrjtfe_mvqueueup" - Move selected track up one queue position
    "rrjtfe_mvqueuedown" - Move selected track down one queue position
    "rrjtfe_clqueue" - Clears queue contents
    "rrjtfe_exit" - Exits RRJTFE and closes extension plugin .exe.
    LABEL CODES
    "rrjtfe_ver" - Plugin version
    "rrjtfe_listname" - Will display "Playlist" or "Queue List" depending on which window is being displayed
    "rrjtfe_searchstr" - Current search string
    INDICATOR CODES
    "rrjtfe" - Plugin indicator
    "rrjtfe_plorql" - Indicator if a "Playlist" window or "Queue List" window is being displayed.
    So...let me know how it goes...
    Cheers!
    Attached Files Attached Files
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    what exactly does this do? You enter a search query and the result is found and played without changing the playlist? If so thats excellent!
    Make sure its plugin manager compatible
    Live mp3Car Facebook Chat
    Aug 2006
    Sun Diego
    Quote Originally Posted by Sonicxtacy02 View Post
    Yup. It works just like DJiK's old plugin except for the fact that it is skin based and not an embedded plugin.
    You can query your current playlist for tracks during runtime w/o changing your current playlist.
    The only difference is that this plugin will have toggle the queue list and playlist since RR can only handle one CL per screen.
    Woodbridge, VA
    Blog Entries
    32
    that sounds great.. i was thinking about implementing something in my skin to handle that with flash.. sometimes i just wanna listen to one song in a playlist and not totally recreate a playlist when searching for one song.
    Aug 2006
    Sun Diego
    Exactly.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    subcribe with high intrest
    Aug 2006
    Sun Diego
    updated.
    Aug 2006
    Sun Diego
    Updated first post w/ beta release.
    Jun 2002
    Virginia
    Nice, Sal. This could be a great addition to RR.
    Jun 2002
    Virginia
    Sal,
    I'm not getting this to work properly. Should Winamp's jump to file plugin be installed also? Should it specifically not be installed?
    With the Winamp JTF plugin installed everything locked up. I removed Winamp JTF and now I'm not having lockups and your plugin correctly finds the files I'm searching for, but I can't select or play any of the files. I'm using your plugin with DFX 4.0; perhaps there's some sort of conflict there.
  1. Replies: 119
    Last Post: 12-25-2007, 03:20 PM
  2. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. jump to winamp plugin?
    By metlok in forum Software & Software Development
    Last Post: 05-12-2002, 11:24 PM
