Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 78
Thread: Cell Phone Bluetooth CallerID for CarPC
  1. #11
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    You posrt is COM9
    The COM10 is incoming connection and it is used if the phone had initiated connection (it is imposible to initiate connection from phone though unless we would start listen to the port at the same time connection is established)
    Any way try port #9 and use default 9600 baud rate
    and i would reccomend to take out ur lass pix as it has you mac address, you dont want me to hack you phone, do u?
    Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
  2. #12
    Jun 2007
    as to the linux part here is the link http://cutecom.sourceforge.net/ we did not write it but it is alnost identical product ... technically you can use terminal window to get access to poerts but I firgot the commands
  3. #13
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by tempgp View Post
    well i have smarter idea, the controll sets will be stored in text file... in the folder that is nabed by the phone model name. so if your generic phone comands do not work we could look in the folder for custom commands... and is fome one has unique phone they can add their comands if they find them on the net. so scalability is not the issue...
    what my problem is that when u initiate the connection to the phone it asks to autorize connection by pressing "OK" button.... i dont lilke that , i want automatic cnection to the phone when u are in the car. For that I think I need to get hands free profile or somethig. All new cars can access your phone w/o autorization (well u need to enter pin code once) so i wonder how that works
    i found out how to auto connect phone to pc when the devices come to distance of each other, here's how:
    right click on the bluetooth icon in the task bar, click on advanced configuration, then click on the local services tab, then highlight the serial com port and click on properties, now just check the box that says "start up automatically" and uncheck "Secure Connection". now just remeber to always allow connection to your phone from the car pc, my phone (sony ericsson w300i) after i add a bluetooth device asks me how i want to treat the new device, if i want to always ask to connect or if i want to always allow connection.
    this worked for me everytime i get into my car i just turn the key and everything is automatic, just make sure you don't let your friends borrow your car, i did and when my friend was dropping my car off to me at work he said the music suddenly stopped the screen said "phone call" and all he could hear was m girlfriend saying "hello, hello".
    also take a look at my sig there is a tutorial on how to setup the audio gateway with widdcomm drivers
  4. #14
    Jun 2007
    Actually I found something similar too
    The auto connect is a part of the Toshoba BT stuck ... but also you have to "autorize" your comp on the phone too, otherwise you will need to confirm connection all the time ;-)
    I wilsh i would know how to undo all the settings on the phone so my CLIP caller ID would start working again
  5. #15
    Mar 2005
    Rockledge, FL
    isn't there a master reset? my ericsson has one, by the way just a quick heads up if you have a verizon phone loaded with their firmware your project just got a lot harder
  6. #16
    Jun 2007
    I dono about verizon firm i got ATT,
    how do u doo master reste on your phone? is that GUI function or is that a secret code?
  7. #17
    Mar 2005
    Rockledge, FL
    well my ericsson still has the sony firmware so inside the seetings menu there is a master reset option, but keep in mind this will erase everything phone number included, if you don't have one try doing a google search sometimes it's a combination of buttons
  8. #18
    Jun 2007
    well the GUI of the phone has the regular reset option and that doesnt not help at all. so I guess i will google for the code... after all how can i continu delopmet if my IDE is not working.
    Hope I dont loose my address book
  9. #19
    Mar 2005
    Rockledge, FL
    you will loose everything on the phone, use bluetooth to take out all your contacts, pics, ringtones, etc.
  10. #20
    Jun 2007
    I got only address book, bus BT doesnt backup sim card addressses, so i hope the fone will not mess with sim card in any way. such as pain
  1. An interesting solution to adding phone support to CarPC
    By AvWuff in forum Hardware Development
    Last Post: 02-08-2009, 01:35 AM
  2. Need help from Bluetooth phone integration gurus
    By Marassa in forum Software & Software Development
    Last Post: 06-08-2007, 01:34 AM
  3. BlueTooth Mobile ( Cell ) Phone Software
    By AMC 96 TE Magna in forum Wireless Communications
    Last Post: 03-23-2006, 07:44 AM
