Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 78
Thread: Cell Phone Bluetooth CallerID for CarPC
  1. #51
    Low Bitrate angel120's Avatar
    Apr 2008
    Queens, NY
    I'm assuming this is what you were looking for:
    And here are my ports:
    2003 Mazda 6i Sedan - White
    CarPC in the making!
  2. #52
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    seams like all works fine
    can u brows the address book?
    oh i know why you got ptoblems. Demo has max of 2Mb file transfer
    Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
  3. #53
    Apr 2008
    Queens, NY
    Damn. Alright, I'll get that fixed soon.
  4. #54
    Jun 2007
    just tur on then turn off BT before you do any test, I managed to get it over like that.
  5. #55
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    Hey, have you guys been following this thread at all:
    http://www.mp3car.com/vbulletin/rr-p...ne-plugin.html
    Seems like these two projects are extremely similar, and it might be a good idea to combine forces. Just a thought.
  6. #56
    Jun 2007
    wow i was looking at it but aorigoiinally he/she didnt use bluesolei.. i better contact that person =)
  7. #57
    Jun 2008
    Tried the program, Awesome. I have found a couple At commands, Still working on more. I have got it to answer a call, Make a data call.... Cant get voice call. When i call the phone just ring ring ring show up, lol. Just to refresh I have Samsung Glyde
  8. #58
    Jun 2007
    I think version curently posted only supports caller ID # and nothing esle
  9. #59
    Constant Bitrate lacning74's Avatar
    Apr 2008
    i installed the parrot EVO bluetooth in my car. it works with the car speakers well but doesn't display numbers. can i use this CallerID program at the same time it is connected to EVO? if so, this would be perfect! i had a lot of issues trying to get my Treo paired with my computer, though, in the past. if CallerID can work with EVO simultaneously, i think i'll get a bluetooth dongle to try-out.
  10. #60
    Jun 2007
    that depands on your setup,...
    you only can heve 1 serial (1 incomming, 1 outgoing) connection between comp and the same device
    If you want to use the same connection for you EVO then you need put thet port on Xport, if your EVO uses HS or HSF or HDA profiles then i have no idea whats gonna happen... well if you have original Toshiba stack then you probably will have multiple ports and that might work. If you have BlueSoleil or anything that combines ports in 1 then i doubt it.
  1. An interesting solution to adding phone support to CarPC
    By AvWuff in forum Hardware Development
    Last Post: 02-08-2009, 01:35 AM
  2. Need help from Bluetooth phone integration gurus
    By Marassa in forum Software & Software Development
    Last Post: 06-08-2007, 01:34 AM
  3. BlueTooth Mobile ( Cell ) Phone Software
    By AMC 96 TE Magna in forum Wireless Communications
    Last Post: 03-23-2006, 07:44 AM
