Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 91 to 100 of 120
Thread: GPSExec Plugin
  1. #91
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by marteline View Post
    Pierrot, I was trying to trigger a sound while the slider moves and it not work with the ONSLDVARNAME command, Enforcer told me this:
    It is greek to me, is it possible to do with your GPSEXEC?
    Can you to try this new version please with the 'ONSLDGPXSLIDER1' option added !
    See the post #78
  2. #92
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by pierrotm777 View Post
    Nicely done! Now we have a sound like a real radar detector while the "radar bar" moves! Very
    cool!
    Thanks my friend!
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  3. #93
    May 2008
    Bordeaux, France
    Smile
    cool!
    Thanks my friend!
    Ok , so , i update the post #78 with this new version
  4. #94
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Pierrot, this can be useful:
    This code play 3 differents sounds for 3 different ranges while GPXSLIDER1 acts
    Code:
    "ONSLDGPXSLIDER1","EVAL;SLDSTATUS;<($GPXSLIDER1$;$PREVSLD$)||EVAL;RANGE_FAR;>($GPXSLIDER1$;40000)||EVAL;RANGE_MID;>($GPXSLIDER1$;15000)||EVAL;RANGE_MID;>($RANGE_MID$;$RANGE_FAR$)||EVAL;RANGE_CLO;<($GPXSLIDER1$;15000)||IFVAR;SLDSTATUS=1;IFVAR;RANGE_CLO=1;PlayWav;$SKINPATH$Scripts\RADAR\CLOSE.wav||IFVAR;SLDSTATUS=1;IFVAR;RANGE_MID=1;PlayWav;$SKINPATH$Scripts\RADAR\MID.wav||IFVAR;SLDSTATUS=1;IFVAR;RANGE_FAR=1;PlayWav;$SKINPATH$Scripts\RADAR\FAR.wav||SETVAR;PREVSLD;$GPXSLIDER1$"
  5. #95
    May 2008
    Bordeaux, France
    Smile
    Code:
    May be , you must to replace Playwav (that doesn't exist) by Playsound ?
  6. #96
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Playwav is a command from bluezx3īs plugin RRextended.
  7. #97
    May 2008
    Bordeaux, France
    Smile
    Ooop, yes in fact !
  8. #98
    May 2008
    Bordeaux, France
    Smile Little update
    New little feature for GPSExec.
    A have added a settings.ini file:
    Code:
    [SETTINGS]
    GPXLatLon=yes
    GPXSlider=yes
    Now you can send or not the GPXLAT and GPXLON.
    Idem for the 'slider' and the 'distance'.
    I have renamed the VB6 project from Gpsexec to Gpsexec1.
    If you want to use two gpsexec instances , just rename into the source each GPSExec1 by GPSExec2 or what you want.
    See the post #78 .
  9. #99
    May 2008
    Bordeaux, France
    Quote Originally Posted by Heather View Post
    Guys
    Can we post this on the app mart? The more apps up there the more we can attract others to this hobby.
    It is a Guino source in first .
    So i can't to do that.
    I think that my script are not enough well written for to be into the app mart.
    May be later , i think to put my better scripts into .
    May 2008
    Bordeaux, France
    Smile
    Code:
    I have defined the variables as follow into the skin.ini file:
    [GPSEXEC]
    SLDSTATUS=1
    RANGE_CLO=1
    RANGE_MID=1
    RANGE_FAR=1
    Code:
    "ONSLDGPXSLIDER1","EVAL;SLDSTATUS;<($GPXSLIDER1$;$PREVSLD$)||EVAL;RANGE_FAR;>($GPXSLIDER1$;40000)||EVAL;RANGE_MID;>($GPXSLIDER1$;15000)||EVAL;RANGE_MID;>($RANGE_MID$;$RANGE_FAR$)||EVAL;RANGE_CLO;<($GPXSLIDER1$;15000)||IFVAR;SLDSTATUS=1;IFVAR;RANGE_CLO=1;Playsound;$SKINPATH$Sounds\CLOSE.wav||IFVAR;SLDSTATUS=1;IFVAR;RANGE_MID=1;Playsound;$SKINPATH$Sounds\MID.wav||IFVAR;SLDSTATUS=1;IFVAR;RANGE_FAR=1;Playsound;$SKINPATH$Sounds\FAR.wav||SETVAR;PREVSLD;$GPXSLIDER1$"
    How do you set the $PREVSLD$ variable please ?
    oops if understand how to !
    Code:
    But your line don't run for me (i have just replaced playwav by playsound and the wav's folder)
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
