Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 120
Thread: GPSExec Plugin
  1. #31
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Re
    Quote Originally Posted by guino View Post
    Well, the settings above are for going NORTH and SOUTH with a 60 degree variation.. I looked at those coordinates with google earth, and it seems in both locations the road is closer to east-west/west-east.. so with those angles selected you could easily not get the commands executed... try removing the angles to see... and make sure your GPS is set in RRConfig (1st thing).
    Ok Guino,
    I try to remove the angles to see .
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    hey hey... haven't seen you in awhile...
    anyway, the search for locations in gpsexec is just not optimized for thousands of points.. I have not tried it myself but chances are it could get slow and use significant amount of the CPU.. but if you'd like to try it, be my guest and let us know how it works..
    hey guino, yea i've been away from the forums lately but i still have 3 carputers going strong running roadrunner or riderunner now. i recently discovered http://www.trapster.com and looking for a way to integrate the database with the carputers brought me back.
    i loaded all 37,500 entries into the ini file and ran gpsexec. on a p4 2.4ghz cpu, gpsexec uses between 10% and 20% cpu and around 29mb of ram. it's a little bit of a resource hog but now riderunner gives me an audio and visual alert of the type and confidence of known speed traps within 500 yds. pretty awesome. thanks guino and good luck with your new business venture.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  3. #33
    May 2008
    Bordeaux, France
    Well
    Quote Originally Posted by kuo View Post
    Hi Kuo,
    Can you to upload the begin of your GPSExec.ini file like exemple please.
    I should like to do the same thing than you but for the france .
    Do you have a special screen for GPSexec ?
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    here's what gpsexec does with the trapster speed trap info when i get within 500yds of a known speed trap.
    Below is a sample of my GPSExec.ini
    Code:
    GPSExec.ini
    41.6568,-71.1698,,,500,YD,"SPEEDTRAP_HIGH"
    41.6719,-71.1519,,,500,YD,"SPEEDTRAP_MEDIUM"
    35.9672,-78.5025,,,500,YD,"SPEEDTRAP_LOW"
    44.625236,-123.083181,,,500,YD,"REDLIGHTCAM_LOW"
    38.932328,-76.901614,,,500,YD,"REDLIGHTCAM_MEDIUM"
    40.88796,-74.057701,,,500,YD,"REDLIGHTCAM_HIGH"
    33.462505,-112.250251,,,500,YD,"SPEEDCAM_HIGH"
    38.938461,-79.883659,,,500,YD,"SPEEDCAM_LOW"
    34.175162,-119.221809,,,500,YD,"SPEEDCAM_MEDIUM"
    I added the following to exectbl.ini. the command lowers winamp's volume to about half, loads a 3 second visual warning, speaks an audio warning.
    Code:
    "SPEEDTRAP_LOW","MENU;WARNING.SKIN||SAY;APPROACHING SPEED TRAP - LOW CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;SPEED TRAP||SETLABEL;!WARNING1;LOW CONFIDENCE||WAIT;3||EXIT"
    "SPEEDTRAP_MEDIUM","MENU;WARNING.SKIN||SAY;APPROACHING SPEED TRAP - MEDIUM CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;SPEED TRAP||SETLABEL;!WARNING1;MEDIUM CONFIDENCE||WAIT;3||EXIT"
    "SPEEDTRAP_HIGH","MENU;WARNING.SKIN||SAY;APPROACHING SPEED TRAP - HIGH CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;SPEED TRAP||SETLABEL;!WARNING1;HIGH CONFIDENCE||WAIT;3||EXIT"
    "REDLIGHTCAM_LOW","MENU;WARNING.SKIN||SAY;APPROACHING RED LIGHT CAMERA - LOW CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;RED LIGHT CAMERA||SETLABEL;!WARNING1;LOW CONFIDENCE||WAIT;3||EXIT"
    "REDLIGHTCAM_MEDIUM","MENU;WARNING.SKIN||SAY;APPROACHING RED LIGHT CAMERA - MEDIUM CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;RED LIGHT CAMERA||SETLABEL;!WARNING1;MEDIUM CONFIDENCE||WAIT;3||EXIT"
    "REDLIGHTCAM_HIGH","MENU;WARNING.SKIN||SAY;APPROACHING RED LIGHT CAMERA - HIGH CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;RED LIGHT CAMERA||SETLABEL;!WARNING1;HIGH CONFIDENCE||WAIT;3||EXIT"
    "SPEEDCAM_LOW","MENU;WARNING.SKIN||SAY;APPROACHING SPEED CAMERA - LOW CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;SPEED CAMERA||SETLABEL;!WARNING1;LOW CONFIDENCE||WAIT;3||EXIT"
    "SPEEDCAM_MEDIUM","MENU;WARNING.SKIN||SAY;APPROACHING SPEED CAMERA - MEDIUM CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;SPEED CAMERA||SETLABEL;!WARNING1;MEDIUM CONFIDENCE||WAIT;3||EXIT"
    "SPEEDCAM_HIGH","MENU;WARNING.SKIN||SAY;APPROACHING SPEED CAMERA - HIGH CONFIDENCE||SETVOL;WINAMP;130||SETLABEL;!WARNING;SPEED CAMERA||SETLABEL;!WARNING1;HIGH CONFIDENCE||WAIT;3||EXIT"
    here is my warning.skin code
    Code:
    RoadRunner Skin
    RRScreen (800x480)"Speed Trap Warning"
    L01,000,165,558,75,255,255,255,40,"Arial Narrow:B","!WARNING","CENTER"
    L02,000,250,558,75,255,255,255,30,"Arial Narrow:B","!WARNING1","CENTER"
    END
  5. #35
    May 2008
    Bordeaux, France
    Thank you Kuo for this very complete exemple .
    I try it
    Thanks again .
    What skin did you use ? Do you have a link ?
  6. #36
    May 2008
    Bordeaux, France
    Wahoo
    I had tried just your exemple and all is right See the fallows picture :
  7. #37
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    how large of a database file have you imported? I'm on trapster too and want to do this.
    Live mp3Car Facebook Chat
  8. #38
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by Sonicxtacy02 View Post
    i downloaded the entire united states trapster database. comes out to 37,437 entries when i downloaded it yesterday. the ini file is around 1,737kb.
  9. #39
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by pierrotm777 View Post
    I try it
    Thanks again .
    i'm using a skin i made quite a while ago. unfortunately the guy who was hosting the files for me took the site down and i lost the backup to a hard drive crash.
    psd's are available here
    Kuo Skin Release
    i uploaded a modified version that changed to fit my needs.
    http://southsea.myftp.org/skin/800x480_day_skin.zip
    http://southsea.myftp.org/skin/800x480_night_skin.zip
  10. #40
    May 2008
    Bordeaux, France
    Question for a little GPSExec add
    Hi Guino,
    I play and play and play again with RR and now GPSExec run very on DFX and Carwings to .
    BUT, is it possible to add two futures in GPSExec plugin ?
    - add a label for distance (metres or miles) between gps position and a poi position .
    - add a slider who give work with the first add (like songpos) .
    Thank again and again .
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
