Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 60 of 120
Thread: GPSExec Plugin
  1. #51
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Csv2GpsExec
    Hi all,
    Csv2GPSExec.exe is a program who convert 4 speedcam files
    found on this web site:
    http://www.alertegps.co.uk/index1.asp
    See the Csv2Gpsexec post here :
    http://www.mp3car.com/vbulletin/soft...ml#post1290443
    Thanksagain for Guino and Kuo files and help .
    Thanks again to the French AutoIt Forum for this program and his help .
  2. #52
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by Sonicxtacy02 View Post
    Thats exactly what i was thinking lol. I'll have to give it a test on my little valley pc this weekend. Kuo, did you use a script to import the data into the .ini? If so could you share?
    sorry for the late response. didn't see the responses in this thread until today. mp3car emails go to an email account i don't often check. sonic to answer your question, i download the two trapster files for the us and copy and paste into an excel worksheet with some formulas. nothing fancy.
    guino, as far as i can tell with 37 thousand entries it still works correctly. every once in a while it will execute commands for locations i'm no where close to. for example i have rr say "welcome home" when i get close to my house but i've had it say welcome home to me when i'm on the other side of town. could it be caused by my gps lock going in and out?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  3. #53
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Possibly...
    There is no GPSValid check in the PI but maybe thats ok as RR is handling all of the GPS data interally anyway, and I'm pretty sure that seeing that guino made this, if he thought that it would have been needed, he would have added it. I could also be wrong and just something he overlooked, I for one would have added that check.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #54
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    it all depends on what your GPS sends... if it doesn't have a lock and it sends the last known position, then it could happen like you said.. the ideal would be for it to send 0 lat, 0 long (middle of nowhere)..
    Ride Runner RR's Myspace
  5. #55
    May 2008
    Bordeaux, France
    New csv2gpsexec version
    I all,
    I had added a new version of my programm for GpsExec Plugin
    Features:
    V1.2 Add GpsPassion Files ,
    Possibility to create your ExecTbl.ini file,
    Possibility to view of your Poi files in Google Earth,
    Multilanguage, English, French, German and Spanish by default, but you
    can create your own language too .
    V1.1 Add Trapster.com files
    V1.0 Only for GpasAlert files (France , England , Belgium , Nederland , Spain , Portugal , Suedish)
    Csv2GpsExec_v1.2
  6. #56
    May 2008
    Bordeaux, France
    Use Gpsexec for SpeedCam alert !
    Hi Guino,
    Can you explain me how to use well the MINHDG and MAXHDG options please for us.
    I leave in France and i have make a gpsexec.ini like that:
    Code:
    ;Test around Bordeaux
    44.812837,-0.555668,300,60,500,M,"RADAR_FIXE_30"
    44.814602,-0.572405,300,60,500,M,"RADAR_MOBILE_30"
    44.844612,-0.598927,300,60,500,M,"RADAR_FIXE_30"
    44.869191,-0.567771,300,60,500,M,"RADAR_MOBILE_30"
    44.872417,-0.565367,300,60,500,M,"RADAR_FIXE_30"
    44.883789,-0.560132,300,60,500,M,"RADAR_MOBILE_130"
    300,60 for MINHDG and MAXHDG are good for the France or another values are better.
    Thanks for your help
  7. #57
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Those are not location dependent. They simply tell the PI what direction you have to be going before it will fire off the cmd.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #58
    May 2008
    Bordeaux, France
    I am sorry , understand bad what do you say . I am french sorry
  9. #59
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    They indicate (pardon the pun) which compass heading you need to be going for the command to be activated.
    There is a maximum and minimum.
    eg if you are heading north you might want a range of 300 to 60 (assuming it can handle going negative)
    heading south you may want 120 to 240.
    Compass = 0 to 360 degrees.
  10. #60
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It should handle 300,60 as anything above 300 or less than 60 degrees. Ehe explanations are all correct -- for each command you should specify which direction is needed to activate the command -- or you can leave them blank for any direction.
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
