Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 70 of 120
Thread: GPSExec Plugin
  1. #61
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    They indicate (pardon the pun) which compass heading you need to be going for the command to be activated.
    There is a maximum and minimum.
    eg if you are heading north you might want a range of 300 to 60 (assuming it can handle going negative)
    heading south you may want 120 to 240.
    Compass = 0 to 360 degrees.
    Thanks Enforcer, thanks Blue,
    So , if i understand my line is ok with a min=300 and a max=60 ?
  2. #62
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by pierrotm777 View Post
    You should get a MAP and look at the direction you'll be going through the road and use that direction to set the min/max parameters.
    If you're using it for RADAR purposes only, then I'd leave them blank as you probably want to be warned when getting close to the radar (independent of the direction you're going):
    44.812837,-0.555668,,,500,M,"RADAR_FIXE_30"
    Ride Runner RR's Myspace
  3. #63
    May 2008
    Bordeaux, France
    Quote Originally Posted by guino View Post
    Firstly , i have tested without min and max , and it gpsexec give me all radar around 500M, not only the radar who are on the road !
  4. #64
    guino's Avatar
    Nov 2004
    Toronto, Canada
    that's exactly right, without a min/max it will give you ANYTHING that is within 500M radius. If you want to be more specific, you'll either need to specify a direction that matches the direction of the specific road OR reduce 500M to a smaller number.
  5. #65
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Guino, is there any chance to add a Indicator, so we can track on RR if GPSEXEC is running?
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  6. #66
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    B71,16,108,101,93,"GPSEXEC||SWITCHBUTTON;1>>CloseW indow;GPSExec||SETIND;!muteRadars;OFF||SWITCHBUTTO N;1",""
    I71,16,108,101,94,"!muteRadars:b
    This function staRt or OFF gpsexec and flash button.
  7. #67
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    But I canīt be sure that the GPSEXEC still working, thatīs why an indicator can be useful
  8. #68
    Oct 2009
    France /Wissous
    Not to my knowledge, but the songs scrolling stutters slightly when GPSexec is activated, it can be an indication.
  9. #69
    May 2008
    Bordeaux, France
    Smile
    I have added an indicator into the cool Gpsexec plugin .
    With this version, when Gpsexec is loaded ,
    1-A !Gpsexec indicator is put ON.
    2-A 'GPSEXECEVENT' command is send when GPSExec is launched
    Please add a !Gpsexec into your screens as:
    I,528,33,39,33,"!GPSEXEC:b",300,500
    If you want to put off the indicator and to quit GpsExec, just use the command
    CLOSEWINDOW;GPSExec||setind;!gpsexec;off
    Just an issue, i have not found how to have an icon into the task bar
    See the post #78
    Good use
  10. #70
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Good use
    First, thanks for the efforts, Are there any other changes besides the indicator and start event?
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
