Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 81 to 90 of 120
Thread: GPSExec Plugin
  1. #81
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Well, itīs time to post the tests!
    Works great! Most amazing is the way that distance range is triggered only when in range of the value that we set in the GPSEXEC.ini and not for a specific value! itīs perfect!
    I just donīt understand the reason for latitude and longitude variables. My guess is that you use to indentify the alert that triggered the warning?
    Thanks a lot for the great new features!
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  2. #82
    Organic Me
    Heather's Avatar
    Sep 2007
    Fells Point, Baltimore, MD
    Blog Entries
    48
    Quote Originally Posted by pierrotm777 View Post
    New features:
    1 event (GPSEXECEVENT1)
    2 latitude and longitude variables (GPXLAT and GPXLON)
    3 distance (GPXDIST1)
    4 slider distance (GPXSLIDER1)
    But these adds use more cpu when an event is fired !
    Guys
    Can we post this on the app mart? The more apps up there the more we can attract others to this hobby.
  3. #83
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    pierrotm777,
    My slider behavior looks like inverted, did you test the slider?
  4. #84
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by marteline View Post
    pierrotm777,
    Nevermind, I just use (Y, Back Slider file path) and replace the slider for some gifs... problem solved!
  5. #85
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    A picture's screen may be ?
  6. #86
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Well, the skin for radar is not finished yet, I implement in a menu;radar.skin to test the slider, as you can see below.
    The left image is for a GPXSLIDER1=50000, the right one GPXSLIDER1=5000.
    I had to put this way because the slider value start high and decrease while you aprouch the target.
    As I told before, itīs not a issue, just feels inverted... hehehe
    It works perfectly and I intend to finish the skin using it till tomorrow!
  7. #87
    May 2008
    Bordeaux, France
    Smile
    Good job and very nice.
    I hope to test your skin fully when you will ready !
  8. #88
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Thanks, You and EL Camino have the first seats to test this skin! It will be ready soon, and I will send to you!
  9. #89
    May 2008
    Bordeaux, France
    That will be with pleasure !
  10. #90
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Pierrot, I was trying to trigger a sound while the slider moves and it not work with the ONSLDVARNAME command, Enforcer told me this:
    Quote Originally Posted by Enforcer View Post
    That command may only be triggered with default RR sliders.
    The only thing I can suggest if it's a plugin or a script then add the command sdk.execute("ONSLDGPXSLIDER1") to the sliders SetSlider and ReturnSlider routines.
    It is greek to me, is it possible to do with your GPSEXEC?
  1. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 09:16 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
