Worked on a little tool/external plug-in for RR on my time off today..
This plugin is meant to execute any desired skin command based on the current GPS location (and optionally) heading.
Upon launching GPSExec, it will look for RoadRunner for 10 seconds, and if not found, it will exit.
If RoadRunner Closes, GPSExec will close with it.
If you wish to manually close GPSExec without closing/exiting RoadRunner, you can use the following skin command: "CLOSEWINDOW;GPSExec"
The source is also attached in case anybody wants to change anything with it. If you do make changes, please share! ;)
You can find GPS locations for most addresses in the world on this page below (then copy/paste it to the GPSExec.INI file):
http://www.gpsvisualizer.com/geocoding.html
Please DO READ the .INI file...
Happy Thanksgiving,
Guino.
