I'll post my config when I make it back to the house. The Computer the screenshot was on, was a P4 2.2GHz. I'll try to get my Lap-top stable enough to see the CPU load on it, its a Centrino 1.76 ghz.
Hi,
i edited your CJSend Script and now it goes with the v1.56.
...but i cannot use, because the high CPU Load
Can someone upload its config.ini, where the CPU Load is down with CJ? On a "normal" PC, without Duo or Quad CPU!
I've been using the 1.56 without any script (to my knowledge) for the past day.
I didn't feel any CPU problems. It worked like a charm.
Didn't check the cpu load though. But it's on a dual Atom board, so plenty of upperarm strength there.
I made a skin file that didn't try to send anything to coverjuke,
so functionality is just flapping through the covers with fingersliding and single taping the cover I'd like to hear.
That works fine, although access to the search function would be nice at some point in the future.
Oh yes, and did a "reloadlist||exit" on the exit button
Henrik
Ok, I have tested the newest version on a pretty basic computer:
Samsung N110
Intel Atom 1.6ghz
1.00 gb RAM
Windows XP SP3
The CPU hovers around 15 to 18 while I constantly cycled through 4 album arts. It may be different if there are MANY covers, but it seemed pretty stable.
Check out the screen shot and coverjuke.ini:
Attachment 55521
toxic000 can you share the edited CJSend script?
Okay thanks ws6vert,
in my Virtual PC is it again at 100% with your coverjuke.ini - but it has no Graphic Card. I test it again in Car with a Graphic Card.
@Schma: simple edit the File Name to *.exe
With this CJSend Version and the good Work from ws6vert i can use the Sendkeys.
With Space Navigator i can scroll through the Folders and select it. In my Skin is also an Button to reload Covers in Coverjuke.
Hi. Are there any released skins that have Coverjunk fully pre-integrated?
Thanks.
Doc Breezy has coverjuke in 506 Breezy I believe, not sure if it has been updated with the new version that does not require the embedder script.
