Page 14 of 16 FirstFirst ... 45678910111213141516 LastLast
Results 131 to 140 of 157
Thread: CoverFlow + RR = Coverjuke
  1. #131
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Back in school this upcoming week. I have made some progress with the overall application. If classes stay light and I dont run into any more coding issues, I should have something to show this weekend.
  2. #132
    Mar 2006
    Quote Originally Posted by ws6vert View Post
    If you need a hand I've been doing VB/Java coding for over 10 years...Haven't touched C# in a long time, but I'm sure I could pick it up if need be. Let me know. Even if you just need someone to test/debug, let me know.
    Also, I may have made some progress on the lockup on certain systems...gonna do some more testing tomorrow but I may have something. Will post once I get a clearer picture.
  3. #133
    Dec 2007
    Just tried the new version... some more nice skins included but it's not embedding into rr.. I am using the newest version of RR.
    Coverjuke 1.56 can be downloaded from Sourceforge. It will embed perfectly with RR, but unable to use sendkeys. To send keystrokes, there is a script posted a few posts back. If u need any help, I can probably put together another help file with everything now that I am back in the US
  4. #134
    Sep 2008
    Baton Rouge
    what are u using for the window handle? It has changed to SDL_app for the latest version.
  5. #135
    Dec 2007
    thank you.. that was the reason for not embedding. now fixed.. will test that new cjsend.exe and see if it works...
  6. #136
    Sep 2008
    Baton Rouge
    I haven't tried it. I was working on another plugin when VS2008 started actng up. I am currently trying to resolve this so I can finish this plugin.
  7. #137
    Nov 2004
    St Louis
    Is the "Cover.exe" compatible with RR if I have Foobar as my media player instead of Winamp?? CoverJuke doesn't seem to be sending the directory list to Foobar.
  8. #138
    Sep 2008
    Baton Rouge
    I could not tell you, becuase I have never tried to use it with foobar. I do know that all cover.exe does is creat a variable called coverjukepath that can be loaded into a list and then played through RR. I think it should not matter what player plays the actual list.
  9. #139
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i dont know if Covers.exe has been changed, but as far as i remember, all it does is sets the path , so RR can see the tracks inside the selected folder, is just a simple command.
    SETPATH;<Selected Folder>
    also in another note, coverjuke.ini has a setting that tells coverjuke to send either the folder path or the entire file list, i havent check how much coverjuke has changed, but the source for Covers.exe was available, in the original thread.
  10. #140
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    I use the latest of coverjuke, cover.exe, only sends me to the RR audio skin nothing more no list of the album i selected. It dont autoplay like the old coverjuke with Cover.exe did.. maybe I misunderstood the setup but I believe you point extenal player to cover.exe correct? I stopped playing with this awhile ago and seeing how you guys posted I figured I'd jump in and ask. I have it setup just dont use it due too I either set it to winamp and it plays but then stays on coverjuke skin and I create button to mainmenu and the album, song showing is'nt the same as the one playing.. i read this thread many times and older CJuke worked..I must be missing something...
    Did it.. Done it... now I got to keep the neighbors kids away!!
  1. Switching between RR and copilot
    By CombatCQB in forum Road Runner
    Last Post: 01-26-2009, 05:27 PM
  2. RR Black screen of death?
    By maxxell in forum Road Runner
    Last Post: 12-17-2008, 09:23 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
