Page 15 of 16 FirstFirst ... 5678910111213141516 LastLast
Results 141 to 150 of 157
Thread: CoverFlow + RR = Coverjuke
  1. #141
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    k, dont forget, RR needs a directory list, to be able to see where to get the files from, no directory list, no files to read. i'll do a quick test today. and see whats going on. maybe something changed in coverjuke.
  2. #142
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    it depends on your coverjuke action variable and the command that u have set for Coverjuke play. I have a plugin that does all of this for you, but my VS 2008 stopped working so I wasnt able to compile the last version, and the one before it is buggy. When I find time, I'll try to get it set-up on a different machine. Until then, if you need it to work immediately let me know and I can work with u to get it to work.
  3. #143
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    well currently I been playing with voice commands to control music but I certainly would like to get this working also.. as its hard to remember hundreds of albums by title.. I set the external player to point to winamp. If its set to cover.exe it chenages screens but just can't get it to play or laod anything into RR.. Currently I set it so the center of Chrysler emblem has button ("reloadlist||exit") upon it exiting to the menu screen.. It still dont update the current music tags? I would simply like to hit album and have it switch to audio sceen and play it.. i am using the same Exbl setting as the first one that was released maybe this is my issue.
    /, CoverJuke
    "COVERJUKE","LOAD;coverjuke.skin;CoverJUke;$RRPATH $Plugins\Coverjuke\CoverjukeLoad.exe;||SETTOPMOST; RR;TRUE"
    "PREVALBUM","ACTIVATE;coverJuke||WAIT;0.1||SENDKEY ;{LEFT}||SETTOPMOST;RR;TRUE"
    "NEXTALBUM","ACTIVATE;coverJuke||WAIT;0.1||SENDKEY ;{RIGHT}||SETTOPMOST;RR;TRUE"
    "GOTOALBUM","||OSKTOCMD;LETTER;SKIPTOLETTER"
    "SKIPTOLETTER","ACTIVATE;coverJuke||WAIT;0.1||SEND KEY;$LETTER$||SETTOPMOST;RR;TRUE"
    "SLCTALBUM","!SELECT||AUDIO"
    "SEEALBUM","MENU;Coverjuke_Playlist.skin||SETPATH; $COVERJUKEPATH$||SETTOPMOST;RR;TRUE"
    "COVERJUKE_ENTER","ACTIVATE;coverJuke||WAIT;0.1||S ENDKEY;{ENTER}||SETTOPMOST;RR;TRUE"
    "COVERJUKE_CANCEL","ESC||GETFOCUS||SETTOPMOST;RR;T RUE"
    "ONEXIT","CLOSEWINDOW;coverJuke"
    Did it.. Done it... now I got to keep the neighbors kids away!!
  4. #144
    Sep 2008
    Baton Rouge
    Yeh it's changed a bit since then. I'll have a look through my old files and see what I can come up with.
  5. #145
    Mar 2008
    I was having the same bit of trouble with the high cpu usage. On my test machine Coverjuke ran fine using a singlecore Atom 230 on a 945G chipset. On my CarPC however I got 54% usage on my Core 2 T2500, meaning one core had 100% load. This on a 945GM chipset, and the performance was choppy to say the least.
    After installing a new Intel Integrated Graphics driver ( actually I went form a ver. 7.0. "something" to a version 6 - the latest available from Intel ) everything is running like a charm.
    Trying to make the CPU work like a GPU - bad idea :-)
  6. #146
    Sep 2009
    Coverjuke 1.56 Elite
    Ok I am new to this and have been beating my self trying to get this to work. I am using the elite skin, I have been able to get the coverjuke 1.56 to embed ok, I created an new skin for it. I have read this thread five times and keep getting clues but still cant get it to work right.
    I have this in the exectbl.ini
    /, CoverJuke (El-Camino)
    "CJ_LOAD","LOAD;coverjuke.skin;Browse by Covers;$skinpath$coverjuke\Coverjuke.exe;!SDL_app"
    "CJ_PREVALBUM","ACTIVATE;coverjuke||WAIT;0.1||SEND KEY;{LEFT}"
    "CJ_NEXTALBUM","ACTIVATE;coverjuke||WAIT;0.1||SEND KEY;{RIGHT}"
    "CJ_SELECT","ACTIVATE;coverjuke||WAIT;0.1||SENDKEY ;{ENTER}"
    "CJ_PLAYALBUM","!SELECT||AUDIO"
    "CJ_GOTOALBUM","||OSKTOCMD;LETTER;CJ_SKIPTOLET TER"
    "CJ_SKIPTOLETTER","ACTIVATE;coverjuke||WAIT;0.1||S ENDKEY;$LETTER$"
    "CJ_VIEWALBUM","LOAD;COVERJUKE_PLAYLIST.SKIN||SETP ATH;$COVERJUKEPATH$"
    which loads coverjuke inside the skin but non of the other commands work. I created buttons for them but they just make coverjuke exit. I know the new version no longer uses cover.exe which I think is the command forwarder, but not sure. I see toxic000 updated the cjsend.exe for the new version but I cant find any docs on how to write the commnad.
    I am also have the playlist update problem, but the thing is when I select the album to play in coverjuke it doesn't exit back to previous skin in stay in coverjuke, so I cant ever try the hidden playlist.
    Thands for your help
  7. #147
    Aug 2008
    i have same issue as you.. This was reason I stopped playing with it. many isssues I had and all the fixes the have posted are for ealier versions.
  8. #148
    Sep 2009
    Quote Originally Posted by toxic000 View Post
    With this CJSend Version and the good Work from ws6vert i can use the Sendkeys.
    With Space Navigator i can scroll through the Folders and select it. In my Skin is also an Button to reload Covers in Coverjuke.
    coverJuke 1.56 and elite lite
    Ok I got more of it working, I download the th new cjsend.exe script and put it in the coverjuke folder. Edited the exectbl.ini with the following wanted commands posted by ws6vert
    Code:
    SENDING KEYS TO COVERJUKE
    1. To send a key to coverjuke simply make a button in your skin that executes the key stroke you want to send according
    to the following list:
    Note: The following list is based on your coverjuke directory being located in C:\Program Files\Coverjuke. If it
    in a different location you will have to update the button code with the correct directory.
    DESC. Button Code
    Next Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{RIGHT}"
    Prev. Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{LEFT}"
    Select Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ENTER}"
    Skip to Letter "RUN;C:\Program Files\Coverjuke\CJSend.exe|{"letter"}" -- Insert any letter (could even be set to a variable in RR, for quick searching)
    1st Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{HOME}"
    last Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{END}"
    Randon Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{SPACE}"
    Jump Right 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGDN}"
    Jump Left 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGUP}"
    Close CoverJuke "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ESC}" *New
    Created a few buttons in the my skin in elite left, right, select and reloadlistex. I can now scroll left and right select the current displaying album and refresh the playlist so elite and coverjuke the same album info.
    When I select the album I would like coverjuke to go to the previous menu. Anyone now how to do this.
    Sep 2008
    Baton Rouge
    Guys... patience. I have posted already that I am working on a plugin for this. There is really no point in wasting your time trying to hack together a working version of the scripts posted earlier. They were written for a previous version of CJ, with a different window handle and apparently a different way of handling keystrokes. So, please be patient. I am in school at the moment, so I dont get much time to work on this, along with VS2008 issues. I will try to find time to work on this, this weekend. Maybe get a basic version working.
  10. #150
    Nov 2004
    St Louis
    Quote Originally Posted by msperano View Post
    Sure, that's easy.
    Open up your coverjuke_playlist.skin and edit the SELECT button to "SELECT||RELOADLIST||EXIT||EXIT"
    If you want it to go to a specific screen like audio player you could also use:
    "SELECT||RELOADLIST||EXIT||LOAD;AUDIO_PLAYER.S KIN"
  1. Switching between RR and copilot
    By CombatCQB in forum Road Runner
    Last Post: 01-26-2009, 06:27 PM
  2. RR Black screen of death?
    By maxxell in forum Road Runner
    Last Post: 12-17-2008, 10:23 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
