Page 2 of 16 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 157
Thread: CoverFlow + RR = Coverjuke
  1. #11
    Low Bitrate docbreezy's Avatar
    Feb 2008
    Maryland
    Quote Originally Posted by ws6vert View Post
    Yeh, this its a bug, the creator knows about it. If using in vista, there is no problem, only in XP.
    I will add instructions to the ReadMe for this issue.
    Has anyone had a chance to see my thread on OSKTOCMD in skins forum? I can't figure it out.
    When you figure the OSKTOCMD out, i would like to know about it. I had to make an alternate OSK menu with the SKIPTO command to browse through the letters.
    On a Different Note, where does CoverJuke get the album artist from? Is it from the tag or from the folder ? I get the album title but not the artists. My aldbums a setup MUSIC\ALBUM and is not organized by artist
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  2. #12
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Quote Originally Posted by docbreezy View Post
    Coverjuke gets the information from the folder titles. I have mine set-up with genre's so it displays the genre in what would normally be the Album text area, and then displays Album - Artist for the album text area. (See Pic)
  3. #13
    Sep 2008
    Baton Rouge
    Doc, did you confirm the GOTOALBUM did not work? Can you try running it with RR Skin Tool to see if it works then? Thats the mystery problem im having. I can get the command to work fine in RR Skin Tool, but when having it assigned to a button in RR, nothing happens.
  4. #14
    Feb 2008
    Maryland
    I figured as much. I'm going to have to re-work my music folders when i have the time.
    As far as search goes, no dice. Getting this working would be nice. Takes me a while to get lower down my list since i dont use the scroll bar. Even so, it's so much fun scrolling, its still my defaauld cover browser.
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  5. #15
    Sep 2008
    Baton Rouge
    You can quick scroll 10 albums at a time with these button commands:
    Jump Right 10 albums, "RUN;$pluginspath$CJSend.exe|{PGDN}"
    Jump Left 10 albums, "RUN;$pluginspath$CJSend.exe|{PGUP}"
    May make jumping around your library a little quicker.
    I'm still searching for a solution to the OSK thing.
  6. #16
    Jun 2007
    Germany
    In Coverjuke Config i have a little Problem with set multiple folders for music.
    I can set only one Folder and also more than one folder. In Coverjuke it displays only the first defined Folder.
    In Config.ini it displays right with the comma.
  7. #17
    Sep 2008
    Baton Rouge
    toxic, I will look into this today, and post up tonight.
    edit:
    Ok I have looked into this, and it appears that coverjuke cannot open multiple folders at one time, but you can select which folder to open at start-up. Just check the box for "Selection of folder at startup," When Coverjuke loads, it will open a screen, and give the option to select a particular folder to open and view the album covers. This is probably not the best way for coverjuke to handle this. I will contact the creator and see if there is any way that it can changed to load out of the separate folders at one time. Word of caution, Coverjuke does not resize the window that allows you to select the folder. So it will probably look extremely weird inside of RR.
    Toxic, how is your music directory set-up? Can you set a top-level folder for all albums?
    ex: C:\My Documents\My Music
  8. #18
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Went through the instructions and this is the result. Is this what it supposed to look like? It's quite different from the screen cap in the first post.
  9. #19
    Sep 2008
    Baton Rouge
    Quote Originally Posted by treetop777 View Post
    Looks good to me, you can turn off all those extra buttons and stuff around the corners in the Coverjuke Config. Since we wont be using coverjuke to play the albums, there is no need for those buttons. Makes it look much cleaner.
    Also, coverjuke is fully skinnable in its self, and can be made to look very good inside of RR, I prefer the xbox style skin because it seems like it would be easier to control on a touchscreen.
  10. #20
    Sep 2008
    Baton Rouge
    GOTOALBUM command has been fixed.
    The fix is as follows:
    Add/change in ExecTBL:
    Code:
    "GOTOALBUM","||OSKTOCMD;CJ_LETTER;SKIPTOLETTER"
    "SKIPTOLETTER","RUN;$pluginspath$CJSend.exe|{$CJ_LETTER$}"
  1. Switching between RR and copilot
    By CombatCQB in forum Road Runner
    Last Post: 01-26-2009, 06:27 PM
  2. RR Black screen of death?
    By maxxell in forum Road Runner
    Last Post: 12-17-2008, 10:23 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
