Page 5 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 157
Thread: CoverFlow + RR = Coverjuke
  1. #41
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Quote Originally Posted by l1nk View Post
    Many thanks! In the meantime I made some changes to the skin and reverted to the previous visual style version (the one based on skinbedder help, but no more skinbedder thanks to your work on scripts!).
    I'm testing to reach a good result but still have the initial delay on loading coverjuke. It takes about 10 seconds to load and position in the right way. Don't know if there's something wrong or simply depends on my carputer (atom 330 based Intel D945GCLF2 motherboard). Please take a look to this video (made with my logitech quickcam connected to my other computer):
    [media]http://www.youtube.com/watch?v=06Redbl_dQQ[/media]
    Are these delays and flickering (don't know if it's the right term!) normal during loading coverjuke?
    I can't be exactly sure when answering this question, but I would have to say that it's probably the speed of your system. What you can do to speed things up is run coverjuke when you start roadrunner. The embedder will look to see if it is open then grab it and embed it. This will allow time for it to open and load your album covers before you can navigate to the coverjuke screen, which will make embedding nearly instant.
    Does that make sense? And the "flickering" is normal when embedding. The script actually grabs coverjuke, then minimizes it, makes some calculations on where to put the window, then maximizes it again. It has to do all these things after coverjuke has started though. I will look into trying to make it flicker less by hiding the window until it is maximized. Maybe V1.3 in the future.
  2. #42
    Sep 2008
    Baton Rouge
    Quote Originally Posted by kimnach View Post
    i am having a bit of a problem here, and not yet being very familiar with skinning, i'm sure it's an obvious problem. coverjuke (and cover.exe) are in the default path.
    my carputer still sits here in my basement and i occassionally tinker with it. i recently found coverjuke and gave it (v1.2) a go tonight. it works standalone--pretty neat--and i will just use the default skin in dfx4.
    using skineditor (0.71), i thought the easy mod would to just change the main menu "music" button (B02 to execute the command "coverjuke").
    coverjuke does launch, but all i get is a bordered window with the default coverjuke controls and my windows desktop showing through. skintool indicates that on pressing the button the embedder executes ("LOAD;coverjuke.skin;!AutoIT v3 Gui;C:\Program Files\RideRunner\Plugins\CJ Embedder V1.2.exe;CJ Embedder"). what have i obviously missed?
    thanks much.
    Kimnach,
    Do you see the application "coverjuke" start, as shown in the video above? Or do you just see the coverjuke embedder application start?
    Also, do you have "CJ_DirPath" defined in your skin.ini?
  3. #43
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Quote Originally Posted by ws6vert View Post
    I'll try your suggestion tonight. Looking forward for your PM on elite skin. Thanks alot
  4. #44
    Jun 2002
    Virginia
    That is the exact issue I'm having. Kimnach, I think you're confusing the loading of the coverjuke skin and the loading of the coverjuke program. The controls you're seeing are in the skin, which is loading. I would bet that if you go to task manager you will not see coverjuke.exe as a running process, which means the program itself is not loading.
    I too have used all the default locations.
    Edit: I now have Coverjuke loading. Here's what worked for me:
    1. Installed the current version of RideRunner, including the dll files that come with the current download;
    2. Uninstalled Coverjuke 1.53 using add/remove programs;
    3. Removed every reference to "coverjuke" and "coverflow" from the registry; and
    4. Reinstalled Coverjuke 1.53.
    I wish I knew which of those actions did the trick, but I now have it loading on two computers. I'm having a couple of issues, including 100% CPU load (100% on a P4, 2.2 GHZ, with 1 GB Ram. The Athlon XP 2800+ 2.08 GHZ with 1 GB RAM runs at 20%. WTF? Is there that much difference between the two chips?), non-working scroll bar and inability to flip albums to see songs or to play albums. I'll see if I can sort those issues out.
  5. #45
    Sep 2008
    Baton Rouge
    Quote Originally Posted by kbreeden View Post
    -I'm not sure what the issue was either. My script will load coverjuke if you set the "CJ_dirPath" variable correctly in your skin.ini. This is the only way my script knows where to look to execute the coverjuke.exe. There should be no "coverflow" in your registry as a result of my script.
    -As for 100% CPU, that must be your system, because mine has used a maximum of about 14% on my centrino laptop.
    -If you read the first post you will know that the issue with the scrollbar is a known bug that I do not have control over.
    -As for flipping the albums to see the songs or the ability to play the album when clicked will depend on your "COVERJUKEACTION" variable, which you also should have defined in your skin.ini, as well as if you set up coverjuke's path to external player as "cover.exe"
    -Quick question, are you running a full version of XP or is this a partial "n-lited" version?
  6. #46
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i'm like ws6vert, i have this in my skin works great , cpu about 9% - 11%, i have a popup that displays the Playlist of selected album, to which you can select just the 1 track or all. i get a little flicker when the popup goes away but thats due to the popup effect i have in place.
  7. #47
    Apr 2008
    Hinckley, Ohio
    -Quick question, are you running a full version of XP or is this a partial "n-lited" version?[/QUOTE]
    ws6vert, i was thinking about this today....i have a minimized xp install (used n-lite) and also tweeked my system by turning off a number of "uneccessary" services. this may be the root of my problem.
    anyone have any idea which services are absolutely needed? i'll try a "hit an miss" approach otherwise.
    btw: yes, only the skin is loading for me. coverjuke does not start, according to taskman.
    greg
  8. #48
    Sep 2008
    Baton Rouge
    greg
    Is "CJ Embedder V1.2.exe" starting? You should be able to verify this in task manager. If it is not, then thats where we need to start troubleshooting.
    If this is true, is RR grabbing the CJ Embedder window or is it just sitting on top of RR?
  9. #49
    Jun 2002
    Virginia
    There was an earlier coverflow plugin that some of us were using. I found a couple of references to it in my registry. I don't know if that was the issue, but anyone who used the coverflow plugin from a year or two ago who is having issues with Coverjuke may want to clean the registry.
    Yes, I'm sure it's my system; I just don't know why. It's good to know that it's not eating up major resources on others' systems.
    Sorry. I meant to say in my earlier post that I hadn't yet gotten a chance to go back through the thread to see if any of my issues had been mentioned.
    Okay, I'll play with that.
    Full XP.
  10. #50
    Apr 2008
    Hinckley, Ohio
    ws6vert et al, i re-installed a full copy of windows (as opposed to the minimal install that i created with n-lite) and coverjuke works! whether it was an errantly set service, a missing component, or something else, a full copy of windows is now my starting point. i'll tweek from here.
    now, i'd like to see coverjuke stay within the limits of dfx4's album/list view window, but that's for another time.....
    thanks again for you efforts!
    greg
  1. Switching between RR and copilot
    By CombatCQB in forum Road Runner
    Last Post: 01-26-2009, 06:27 PM
  2. RR Black screen of death?
    By maxxell in forum Road Runner
    Last Post: 12-17-2008, 10:23 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
