great to hear that you got it working. Im not sure what you mean by staying within a certain window, you will have to elaborate.
If you have View folder window at startup set to true via:
firstfolderwindow = true
Then the following button code will close coverjuke, unload cj embedder, exit the current screen and reopen the coverjuke.skin and voila you're back to the folder list.
Code:"RUN;$pluginspath$CJSend.exe|{ESC}||CLOSEWINDOW;CJ Embedder||EXIT||COVERJUKE"
GizmoQ and Toxic!!
I found it! Sending the key F12 to coverjuke will allow you to open the folder view box and select the directory to view your covers in! The button command for your skin is as follows:
This allows alot more flexibility with coverjuke. You can now load all covers, or select them based on Genre, Artist, or however you have your music directory set up!Code:"RUN;$pluginspath$CJSend.exe|{F12}"
I will be adding this button command to the CJSend portion of the ReadMe!
i suppose i better add this button then as i know some1 would want it lol....
Yeh possibly, Im going to start looking into skinning coverjuke to hopefully show how well it can look. With the ability to change folders inside of Coverjuke, this could easily replace the typical music library browser inside of RR. It could also replace the video library as well! All it needs is to be skinned to look like the skins that we use.
