what i thought to but it still scans the music folder , unless i have a setting wrong
Same here... Maybe usecache is still unused by the coverjuke or simply it does not work as supposed
It does work, I could send you my cache file and it wil load all the information about my covers, it's just unable to load the actual image. I believe the way this program is written, is it caches the data for each of the covers, and then when the program is run, it knows eactly where to go to get the image to use for the software. If it were to make a copy of each image, for loading via a cache system similar to the internet, it would be a pretty big cache file and folder.
Do you have selected "use cache data" and "fast loading cover"? Mine load up pretty quickly with these two parameters checked.
Coverjuke 1.54 was released this week, and with the improvements to this version.... It embeds perfectly without the need of the CoverjukeEmbedder script! I will update the first post to remove the download files and give instructions for embedding in RR.
well at 1st look much much better ,Embeds very nicly and no scanning on start up as well, now to see what else is in here lol...
what is the code line in ExecTBL.ini
"COVERJUKE","LOAD;coverjuke.skin;$skinpath$coverjuke\Coverjuke.exe;Coverjuke"
seems not working
"COVERJUKE","LOAD;coverjuke.skin;Browse by Covers;$skinpath$coverjuke\Coverjuke.exe;!SDL_app"
The only thing I see as a problem, is that CPU usage it up from normal. Not sure why. I havent been able to use SENDKEYS with it embedded either, but I'm still investigating. If anything, I can rewrite CJSend to work.
New version works pretty nice but...
when i select an album coverjuke does not exit automatically to audio player like the old one used to.
Also if i exit via the exit button(in the skin, not coverjuke) i get to audio player, but it still shows the earlier album but its playing the album i just selected.
Any solution for these?
