Page 18 of 27 FirstFirst ... 89101112131415161718192021222324252627 LastLast
Results 171 to 180 of 267
Thread: CoverMess 0720 - Bug fix update
  1. #171
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    OK, ran a test to see if my paths.txt worked, I've attached a video to demonstrate the test...I'm running with discardable , so cm restarts on each try...
    First test, paths.txt exists, loads in about 1 second..
    Second test, delete paths.txt, run CM, takes about 4 seconds to scan hd and creates new paths.txt as I point out..
    Third test, run CM again, loads in about 1 sec, so it is reading from paths.txt..
    This is what the first few lines of my txt file look like...
    0
    LSTc:\testmusic\Music\Classic Rock-Metal\- Various -\folder.jpg
    LSTc:\testmusic\Music\Pop-New Wave\- Various -\folder.jpg
    LSTc:\testmusic\Music\Classic Rock-Metal\10,000 Maniacs\folder.jpg
    LSTc:\testmusic\Music\Classic Rock-Metal\10cc\folder.jpg
    LSTc:\testmusic\Music\Classic Rock-Metal\38 Special\folder.jpg
    LSTc:\testmusic\Music\Pop-New Wave\A Flock Of Seagulls\folder.jpg
    LSTc:\testmusic\Music\Pop-New Wave\A Ha\folder.jpg
    LSTc:\testmusic\Music\Pop-New Wave\ABC\folder.jpg
    Note the zero on the top, does yours have this?
    Attached Files Attached Files
  2. #172
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i think i can see whats happing running skin tool log attached you can see it setting the path and loading the paths.txt ,then the cl is cleared then it loads the just a folder.jpg,and saves that cl list giving mea single line paths.txt with just a folder.jpg
    skintool log
    LOAD;FLASHBROWSER.SKIN
    ONSCREENCHANGE
    SETVAR;MUSICP;F:\Music\
    SETFLASHVAR;MUSICP;F:\Music\
    CLCLEAR;ALL
    CLLOAD;C:\Program Files\RideRunner\Skins\Ranger AWRR\paths.txt
    SETPATH;F:\Music\
    SEARCHFILES;
    CLCLEAR;ALL
    CLSAVE;C:\Program Files\RideRunner\Skins\Ranger AWRR\paths.txt
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #173
    Mar 2008
    Toronto Canada
    Try this one...I've doubled the timeout values..
  4. #174
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sorry nope its still the same its that 2nd cladd on the start that looks like the problem is it the same cmd as refresh folders as that works ok
  5. #175
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    [QUOTE=carputer1;1327586]i think he means the area size if you make that smaller than 800 x 483 , you loose the bottom button(folder ) and label for page and albums,
    [QUOTE]
    You have to use a config file and change the button positions in order to fix this problem. Same with losing the flip button on the covers.
    New Age Garmin - Skin for RR
  6. #176
    Aug 2006
    West Allis, WI
    I have one request for you Pete..
    How about the ability to change the txt color on all the buttons. And also be able to make them totally opaque.
    If I set the alpha to 100, they are still slieghtly transparent.
  7. #177
    Aug 2006
    West Allis, WI
    Sorry one last post... THIS IS AWSOME.. I love this version. I have been using the first version with my skin now ever since it came out and it has been great. But the additional features added in this one push it over the top... THANKS
  8. #178
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    its not my problem just trying to let pete know what pafftis meant , the screen size is perfect for me with the new button images.
    @pete
    if you can add text to each button Great, but i have a request if possiable,
    instead each button holding the font type can it read a var from the skin.ini
    and the size of text of each button, i know the color is a problem ,
  9. #179
    Mar 2008
    Toronto Canada
    Quote Originally Posted by ThunderStick View Post
    button txt settings in the works(couple of days), as for the alpha, i think it ranges from -255 to 255, try that....
  10. #180
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    great news pete ,this is really starting to come really alive now , even thou this is my test machine , and my music folder is a little weak on amount of tracks , and not very well done , i even started to add some missing art to my music just to get the full effect,
  1. Intel D945GCLF2 Dual-Core Atom
    By txspazz in forum General Hardware Discussion
    Last Post: 08-15-2010, 02:06 PM
  2. FlashFlex 2nd test release 03/26/09
    By pcpete in forum RR Skins
    Last Post: 04-14-2010, 04:38 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. How do you flash without Floppy or CD?
    By marc456 in forum Software & Software Development
    Last Post: 01-23-2007, 07:14 PM
  5. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 04:50 PM
