Page 19 of 27 FirstFirst ... 9101112131415161718192021222324252627 LastLast
Results 181 to 190 of 267
Thread: CoverMess 0720 - Bug fix update
  1. #181
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Quote Originally Posted by carputer1 View Post
    sorry nope its still the same its that 2nd cladd on the start that looks like the problem is it the same cmd as refresh folders as that works ok
    If it finds a valid paths.txt it should not execute the following..
    SETPATH;F:\Music\
    SEARCHFILES;
    CLCLEAR;ALL
    CLSAVE;C:\Program Files\RideRunner\Skins\Ranger AWRR\paths.txt
    It seems like my check if a paths.txt exists is failing for you....
    So it works when it scans the HD, but creates a paths.txt with just folder.jpg...
    hmmm..oh.. make sure the following is in your covermess skin...
    L,0,0,0,0,,,,,,"CUSTOMDL",
    L,0,0,0,0,,,,,,"CUSTOMPL",
    L,0,0,0,0,,,,,,"CUSTOMCL",
    F,0,60,800,480,"RFCM_albumstxt.swf"
    S01,-1000,-1000,1000,1000,255,255,255,255,255,255,255,255,255 ,0,0,0,5,143,233,false,18,"Arial"
    S01,-1000,-1000,1000,1000,255,255,255,255,255,255,255,255,255 ,255,255,255,false,12,"Arial"
    SC01,-1000,-1000,300,500,255,255,255,255,255,255,255,255,255,2 55,255,255,false,18,"Arial"
    all hidden playlists are necessary as well as the labels...
    for that matter can you post your skin file?
  2. #182
    Mar 2008
    Toronto Canada
    Quote Originally Posted by ThunderStick View Post
    Sorry one last post... THIS IS AWSOME.. I love this version. I have been using the first version with my skin now ever since it came out and it has been great. But the additional features added in this one push it over the top... THANKS
    Thx man, glad you like it...any issues with reading paths.txt?
  3. #183
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    skin file is as above yours .the load results i gave you happen every time i load cm,
    but when loaded if i use the reload button it creates another path.txt correctly done.
    which again gets deleted when i load the skin again
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #184
    Mar 2008
    Toronto Canada
    ok, so it generates a good paths.txt, when you rerun cm it fails the check, then deletes and regenartes a new one from scan hd...
    Can you post a few lines from the top of your paths.txt?
  5. #185
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    on load of skin
    0
    when skin is loaded and use rescanbutton
    0
    LSTF:\Music\ACDC\'74 Jailbreak\folder.jpg
    LSTF:\Music\The Cult\(1991) Ceremony (With Bonus Tracks)\folder.jpg
    LSTF:\Music\The Cult\(1994) The Cult (With Bonus Tracks)\folder.jpg
    LSTF:\Music\The Cult\(2001) Beyond Good And Evil (With Bonus Tracks)\folder.jpg
    LSTF:\Music\Jean Michel Jarre\1976 Oxygene\folder.jpg
  6. #186
    Mar 2008
    Toronto Canada
    Delete your paths.txt file...then try this swf, I changed where i put the command fscommand("GETCL","");
    If all is well it should generate a proper new paths.txt on first run automatically, do not press button. On subsequent runs, it should load automatically from paths.txt...
    I was able to read your paths.txt here..
    Attached Files Attached Files
  7. #187
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sorry to say this but afraid not still the same
    deleted paths.txt / closed rr / restarted rr / loaded cm /path.txt got created but with 1 folder.jpg/ reloaded rr again / loaded cm/ same again
    so tried rescan worked got full paths.txt /reloaded rr/loaded cm / back to square 1 again
    are you ables to make the load cmds 1 hit only , meaning only work on 1st load and never again,
    your lucky i can't sleep lol...
  8. #188
    Mar 2008
    Toronto Canada
    something definately wonky, i'll have to do some more tests, anyone else have similar issue, thunderstick? pafti?
  9. #189
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    okgot it my problem well sort of, its my inc files i ahev a INC,Borders.skin in my skins, 1 with a hidden playlist and 1 without, but haveing the playlist is not the problem , its the fact i have and inc file, will dig more to find out whats killing cm on load , you can rest for a bit till i home in on this 1
  10. #190
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok found my probelm its another flash object i have in my inc file MDG's flash clock
    if i remove this your cm works as should. i have no idea how to over come this.?????
  1. Intel D945GCLF2 Dual-Core Atom
    By txspazz in forum General Hardware Discussion
    Last Post: 08-15-2010, 01:06 PM
  2. FlashFlex 2nd test release 03/26/09
    By pcpete in forum RR Skins
    Last Post: 04-14-2010, 03:38 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  4. How do you flash without Floppy or CD?
    By marc456 in forum Software & Software Development
    Last Post: 01-23-2007, 06:14 PM
  5. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 03:50 PM
