Page 21 of 27 FirstFirst ... 1112131415161718192021222324252627 LastLast
Results 201 to 210 of 267
Thread: CoverMess 0720 - Bug fix update
  1. #201
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Looks like you're not editing any settings, the included artists.txt settings allow you to change the position size color etc of every button...
    also your covermess skin that loads the swf has parameters to change the size of the flash object..
    ie mine is
    F,0,60,800,480,"RFCM_albumstxt.swf"
    the 0,60 is top left corner and the 800,480 is the width x height
  2. #202
  3. #203
    Mar 2008
    Toronto Canada
    Quote Originally Posted by ThunderStick View Post
    I have one request for you Pete..
    How about the ability to change the txt color on all the buttons. And also be able to make them totally opaque.
    If I set the alpha to 100, they are still slieghtly transparent.
    New release 0714 allows custom text, and text settings now
    As for opaque try 255 for alpha value
  4. #204
    Mar 2008
    Toronto Canada
    Quote Originally Posted by carputer1 View Post
    if you can add text to each button Great, but i have a request if possiable,
    instead each button holding the font type can it read a var from the skin.ini
    and the size of text of each button, i know the color is a problem ,
    You can put all the settings in your skin.ini file...
    Rename swf to
    RFCM_skinini.swf
    and change covermess skin to reflect this...
  5. #205
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    here i go again lol... nice pete i can see you have made it so i can ctrl the font and the size of each button thankyou
    now to port the new settings into my settings
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  6. #206
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    here you go pete the fruits of your labour only 1 thning i need to ask, the drop down menu buttons across the top, is there away to ctrl the font size there , the labels are good ,its the selected label underneath look at scr cap at alpha button you will see what i mean.
  7. #207
    Mar 2008
    Toronto Canada
    Sweet!!
    all menu header buttons allow for top text and bottomtext sizing
    eg
    &alphabuttextsize=24&END
    &alphabuttoptextsize=20&END
    &alphabuttextfont=ARIAL Narrow&END
    &alphabuttextcolor=0xffffff&END
    &alphabuttextalign=Center&END
  8. #208
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    cheers pete missed that 1
  9. #209
    Mar 2008
    noise very good!! ths!!! respect man!!
    my edit 640x480 size
    --------------Back Cover Button Settings------------------------
    &selbutx=177&END
    &selbuty=-90&END
    &selbutw=60&END
    &selbuth=60&END
    &selbuta=64&END
    &selbutrgb=0x0000ff&END
    &selbutimage=&END
    &selbuttextsize=28&END
    &selbuttextfont=ARIAL NARROW&END
    &selbuttextcolor=0xffffff&END
    &selbuttextalign=CENTER&END
    &selbuttext=&END
    does not display!!!!
    Attached Files Attached Files
    RUSSIA - WINER!!!
  10. #210
    Mar 2008
    Toronto Canada
    thats the default settings for that button, that button is on the back cover only, when you press flip...it looks like a check mark..
  1. Intel D945GCLF2 Dual-Core Atom
    By txspazz in forum General Hardware Discussion
    Last Post: 08-15-2010, 02:06 PM
  2. FlashFlex 2nd test release 03/26/09
    By pcpete in forum RR Skins
    Last Post: 04-14-2010, 04:38 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. How do you flash without Floppy or CD?
    By marc456 in forum Software & Software Development
    Last Post: 01-23-2007, 07:14 PM
  5. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 04:50 PM
