Page 23 of 27 FirstFirst ... 131415161718192021222324252627 LastLast
Results 221 to 230 of 267
Thread: CoverMess 0720 - Bug fix update
  1. #221
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    cheers pete
    the add and play on the stage screen don,t seem to do anything, how are they suppose
    to work
    great job thankyou
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #222
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    The will play/add a whole genre, or , play/add a whole artist if you filter a specific artist....
    Does it not work for you? Just test with latest release and its working here...
  3. #223
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    yes it dose work now i know what to look for , in last version nothing happened, but now it dose ,
    i alos looked through the settings for away to get rid or replace the track list images .
    this is on flip of cover i get what i could only discrbe as a ghost bubble around each track in the list ,, it dose look outter place, also how do you expand the list or art width, as the list gets cut off by the buttons along side of the list ,,
    knowing me its there just don't see it
  4. #224
    Mar 2008
    Toronto Canada
    Not sure what you and thunder are seeing , screenies would help...a couple of things to check...
    - CM no longer needs jpg or otherwise specified in audiofiles in rr.ini
    - If you specifiy a non existant graphic for a button image ie fake.jpg..the bubble will go away
  5. #225
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i have just noticed what Thunder is saying
    look at the line the track is duplicated on each line
  6. #226
    Mar 2008
    Toronto Canada
    Ah, cool ...never seen that here , must investigate...
    As for the bubble , check my previous post for solution
  7. #227
    Mar 2008
    Toronto Canada
    Ok, able to recreate issue with double song names...I have ID3 disabled ie useid3=0, in my rr.ini...once I set it to useid3=1 I get the double names as well..
    It seems RR returns this when fscommand("GETDL","") is executed ...
    should be able to find a flash fix
  8. #228
    Mar 2008
    Toronto Canada
    Ok, thunder and carputer, test this version, should fix the double names, also if useid3=1, then showextensions flag in rr.ini will also be honored...
    Attached Files Attached Files
  9. #229
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well it works for me ,,, Thunders turn lol...o and as you can see played with the bubles looks alot better now thanks pete,
  10. #230
    Mar 2008
    no button flip to size 640x350 =(((((((((
    RUSSIA - WINER!!!
  1. Intel D945GCLF2 Dual-Core Atom
    By txspazz in forum General Hardware Discussion
    Last Post: 08-15-2010, 02:06 PM
  2. FlashFlex 2nd test release 03/26/09
    By pcpete in forum RR Skins
    Last Post: 04-14-2010, 04:38 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. How do you flash without Floppy or CD?
    By marc456 in forum Software & Software Development
    Last Post: 01-23-2007, 07:14 PM
  5. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 04:50 PM
