Page 24 of 27 FirstFirst ... 1415161718192021222324252627 LastLast
Results 231 to 240 of 267
Thread: CoverMess 0720 - Bug fix update
  1. #231
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i have just tested you screen size, i do get the the flip button ,
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #232
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    thx for helping out carputer1, I also tested, seems to be fine here...
  3. #233
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i wonder , have you played with the button settings in albums.txt you may of moved it off screen , or somthing, have you got the last release pete put out , in post 228 above
    there was an issue before as pete mentioned a few post back .
  4. #234
    Mar 2008
    Toronto Canada
    Yeah, he could be on an older version, or button off screen..
    BTW....just released a bug fix version 0720 on first post
    This has all previous sizing and double names fixes plus it will work with all versions of RR
  5. #235
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    pete yet another request if pos
    i have now moved your great creation to skinpath plugins folder i think it a good place to have it. anyway the infobutton box which you see in my scr shots is now top right. but it disappears when i go to stage view can this be added so it appears in stage view as well, useing the same settings in the album.txt.
    thank you
  6. #236
    Mar 2008
    Toronto Canada
    so you want the info button to always display?
    The info button was originally just for debugging, but decided to keep it.
    Was thinking of making it more flexible as well as adding options for more info, actually would be cool if pressed it would expand to show more info.....hmmm
  7. #237
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well i like your thinking but can i suggest a few things that may help flexabily a bit more
    yes i do want it to display all times , great minds think alike lol...
    having clickable to give more info great move.
    if you can allow my special request for using other image to read the skinpath variable
    $SKINPATH$XXXX\XXXX\XXXX
    that would be
    a great step for me at least , and also for any other skins that will use this , as you said
    the skin.ini can be used for the settings, but if your like treetop777 who has evry skin under the sun (skin junkie lol) the settings can be in each skin.ini and your app in rr root plugins folder ,
    so for example , cm in rr root plugins
    the user loads my skin of which use's external images ( settings in skin.ini)
    then loads lets say Teknik4 skin without external images (settings in skin.ini)
    it will just make things alittle easyier dose this make sense , bloody speech to text is playing up sorry.
  8. #238
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Actually how about having the albums.txt in each skin
    And cm looks for it before load
    1st looks in it's own where that folder is if not found look
    In skinpath for it.
    I think that's how you are doing it for paths.txt or close to it
  9. #239
    Mar 2008
    Toronto Canada
    Ok, so I'm going to make it so that the swf(s) can reside anywhere you want and the paths to the settings, paths and images can handle rrpath, skinpath etc....right?
    eg put .... RFCM_$skinpath$albumstxt.swf in rr root folder ( or plugins)...
    in albums.txt one could put..
    &cover=$skinpath$folder.jpg&END
    &defaultpaths=$skinpath$paths.txt&END
    &shufbutimage=$skinpath$paw.png&END
  10. #240
    Mar 2008
    Toronto Canada
    Quote Originally Posted by carputer1 View Post
    In skinpath for it.
    Yeah, if skinpath or whatever not specified, will look for settings in swf folder, if not there, will look in skinpath floder, if not there will use builtin default settings..
  1. Intel D945GCLF2 Dual-Core Atom
    By txspazz in forum General Hardware Discussion
    Last Post: 08-15-2010, 01:06 PM
  2. FlashFlex 2nd test release 03/26/09
    By pcpete in forum RR Skins
    Last Post: 04-14-2010, 03:38 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  4. How do you flash without Floppy or CD?
    By marc456 in forum Software & Software Development
    Last Post: 01-23-2007, 06:14 PM
  5. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 03:50 PM
