Originally Posted by
EL CAMINO
is there a way to change the data in this label, from an Extention plugin? i tried to set different data and the result was, "TAGTITLE data and NEW DATA" so in other words, if TAGTITLE use to show "BLACK", then in my plugin i want "TAGTITLE" to show "KASHMIR" what RR is showing is both at the same time. "BLACKKASHMIR", i can change indicators but not this labels. so if is possible i can use some help here,by the way i'm using vb 6.0 in a very basic plugin (
RRTube).
very simple.. here's how i change "trackname" for rrshoutcast.
Code:
Public Function ReturnLabel(ByVal LBL As String, ByVal FMT As String) As String
Select Case LCase(LBL)
Case "trackname"
If ShoutcastStatus = "Tuned" Then
ReturnLabel = RRShoutcastTrackName
End If
End Select
End Function
This code preserves the TRACKNAME label unless my plugin is "Tuned". And RRShoutcastTrackName is of course a variable set by a timer function. TAGARTIST,TAGNAME, and any other label can be modified from an extension plugin in the same manner
