Results 11 to 20 of 22
Thread: iTunes Player Plugin
  1. #11
    May 2008
    Guino,
    Thanks for the fast reply. Itunes supports a very robust scripting interface, and there is an embed artwork script, which i have run, it can be found here:
    http://dougscripts.com/itunes/script...hp?sp=embedart
    There is also a script to save a copy of the artwork in the folder:
    http://dougscripts.com/itunes/script...p=savealbumart
    Assuming both of those scripts had run, what are your thoughts?
    Hans
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by hans14914 View Post
    Guino,
    Hans
    If the second script (save albumart to folder) runs, then you should have an image on the folder for the songs you're playing -- if this is the case, RR will automatically read and display that image as the album art. The only requirement is that the coverfile setting matches the extension for the files iTunes writes. So if iTunes is saving PNG files, set coverfile=*.png in RR.INI, if it saves BMP files, then set coverfile=*.bmp in RR.INI and if it saves JPG files, then set coverfile=*.JPG ... as long as a valid file is in the same folder, then RR will display it.
    Ride Runner RR's Myspace
  3. #13
    Raw Wave
    Jun 2002
    Virginia
    I have had difficulty with the itunes library being imported properly into winamp. It duplicated every song twice, and shows the file extension - like its not reading the tags. I will try foobar, and see how it does, but it sure seems if there is iTunes support, that it would be the logical choice.
    I'm not sure if this is the issue you're referring to, but I have been using this little script to convert itunes playlists into Winamp playlists.
  4. #14
    Jun 2010
    struggling
    I have not been able to get this to work.
    I am using windows 7, i can't get past the regsrv32 part?
    followed the readme.txt and i suck
  5. #15
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    could be nice if plugin was able to use itunes for mgt. of songs so we did not have to use scripts etc...
    another thing to consider is that if you have got stuff from itunes its sure protected so that you need either itunes to play.. only other player i know that can play stuff from itunes are BASS
    thinking of it... Why not use Itunes for both music and Video?
    Blessed are the "cracked" for it is they who let in the light.
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by boelle View Post
    We really need to add iTunes to the swear filter.
  7. #17
    Oct 2008
    Odense, Denmark
    ITunes
  8. #18
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Enforcer View Post
    You can say that again!!! iTunes is just like those people that own a huge SUV say like a hummer and only use it go 5 minutes down the street to the groc store and back. Big waste of resources
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #19
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    Hey, sorry to dig up a [semi] old thread. Haven't been on the forums in a while, had a question:
    Say I'm controlling iTunes manually with my main screen, and have a second 'non-touchscreen' (say backseat) running RR which only displays information about the currently playing song.
    1) Will the second (backseat) screen running RR automatically update song information whenever I change a song manually on my main iTunes-only screen?
    Basically I'm trying to figure out whether this plugin:
    -ONLY sends commands to change the song in iTunes, and then pulls its own info about the song from the RR database.... OR
    -if it actually retrieves current song info from iTunes, and updates as the song changes (whether it was changed via RR or manually via iTunes).
    Hope this makes sense. Thanks
  10. #20
    Mar 2006
    Houston, TX
    bump!
    Does RR actually read the currently playing song info from iTunes?
    OR
    Does RR only send commands to iTunes, displays the song it thinks iTunes is playing, and expects it to obey?
  1. Sound problem nissan primera p12 cd player
    By shsa007 in forum Car Audio
    Last Post: 02-01-2011, 01:59 PM
  2. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  3. List of available plugins and features
    By JohnWPB in forum RR Plugins
    Last Post: 10-25-2008, 07:16 PM
