Results 1 to 10 of 18
Thread: iTunes Player Plugin
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow iTunes Player Plugin
    iTunes Player for Ride Runner
    Description:
    This is a player plugin for Ride Runner which uses iTunes as the audio engine.
    Purpose:
    This plugin provides the choice to use iTunes with Ride Runner instead of winamp/wmp/fmod/foobar2000.
    Requirements:
    -iTunes 8.1.1.10 or newer (Tested with 8.1.1.10)
    Available at: http://www.apple.com/itunes/download/
    -Ride Runner 5-1-2009 (Untested with previous versions)
    Available at: www.nisuautomotive.com
    Installation:
    -Copy iTunesRR.DLL to the desired location of install and use regsvr32 to register it.
    For instance: regsvr32 iTunesRR.DLL (from a command prompt)
    -In RR.INI set (make sure there's no winamppath= setting):
    player=iTunesRR
    playerpath=c:\program files\iTunes\ (location where iTunes is installed)
    visuname=iTunesVis
    -Open iTunes by itself (while RR is NOT running), and:
    Open Menu Edit->Preferences and UNCHECK "Check for updates automatically"
    Choose the Visualization you want to use in RR (from the menu)
    Considerations:
    -This is a BETA plugin -- please report any bugs/suggestions
    -iTunes is quite memory demanding, it may take a considerable amount of time to start the player.
    -iTunes Visualizations can be quite CPU intensive and may slow down RR a bit when they're running.
    -If you have multiple monitors, iTunes may flash briefly when first starting a visualization.
    -This player does NOT implement any iTunes library support. Another plugin could be done for that.
    -Any files you play with this plugin that are NOT yet in the iTunes library will be added to it.
    Attached Files Attached Files
    Ride Runner RR's Myspace
    May 2008
    I have a large collection of ALAC files, so I am very interested in the ability of RR to use iTunes as the default music player. How does the current implementation of this plug-in handle playlists and music directories? In the above "Considerations Section" it mentions that there is not iTunes library support, and also that any file not in the library will be added to it. How could i use my existing iTunes library to show up in RR while not being duplicated in iTunes?
    Hans
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by hans14914 View Post
    Hans
    You can also play ALAC in winamp or foobar with the right plugins. Either is a much better option in my opinion.
    May 2008
    I have had difficulty with the itunes library being imported properly into winamp. It duplicated every song twice, and shows the file extension - like its not reading the tags. I will try foobar, and see how it does, but it sure seems if there is iTunes support, that it would be the logical choice.
    Jun 2009
    I could really use this because it is the simplest way to integrate my iPhone's music into RR. I was wondering how much you had working with the plugin. I only seem to be able to play/pause and select the position within a song. I don't get track info and I can't skip forward or backward. It may be because I am using iTunes 8.2.0.23.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by ABProbe88 View Post
    Haven't tested that version of iTunes, but that should not matter for forward/backward. If the iPhone has the same database as iPods do, then the best way to interface with RR is using RR's built-in interface to the iPod -- which is 100% independent of which AUDIO player you use (so you can use winamp, foobar, wmp, etc)..
    PS: All of the available AUDIO players for RR implement AT LEAST: PLAY/PAUSE/STOP/FFWD/RRWD, Playlist Management, Volume/EQ control and Visualization.
    Jun 2009
    The reason I want to implement this is because it has a different database than the iPod (also I can't seem to get shuffle to work, but that is a minor concern). The only way to get access is by using programs or SSH, neither of which is easily workable. Also should the plugin give track information?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Plugin install instructions updated.
    @ABProbe88: This is only a player plugin, so it only uses iTunes as the audio engine. It DOES NOT provide any database or song management features.
    May 2008
    Guino,
    What is the best way to import an itunes databse into RR so the correct coverart and song info are listed? Will MediaRR do this with some modifications?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    To import the music over read those:
    http://forums.winamp.com/showthread.php?postid=2290246
    http://mp3.about.com/od/tutorials/ht/Winamp_itsongs.htm
    I am unaware of a way to import the cover art because I think itunes keeps it stored elsewhere. Maybe I can dig up the information on the itunes SDK to see if they make the image available somehow, but I doubt it.
  1. Sound problem nissan primera p12 cd player
    By shsa007 in forum Car Audio
    Last Post: 02-01-2011, 01:59 PM
  2. nGhost 2.0.0 Final is out!
    By tripzero in forum LinuxICE
    Last Post: 07-16-2009, 10:16 PM
  3. List of available plugins and features
    By JohnWPB in forum RR Plugins
    Last Post: 10-25-2008, 07:16 PM
