Originally Posted by
vinchan
Hi Guino,
As you guided, I add "VISU||TRANSPARENT;FoobarVis;60;true" in Audio_Player.skin, and it works.
However, on the other
machine, it doesn't work. The visulization did come out, but not transparent.
Did I miss something?
PS. Both laptops have same configurations.
Thanks in advance!
If they have same config (O.S., CPU, MEM, Drivers, AND RR SETTINGS, etc) then they should work the same. I would check that the command is correctly spelled on the machine that doesn't work. If it is ok, then try this instead:
Code:
"VISU||DELAYEXEC;2;TRANSPARENT;FoobarVis;60;true"
If nothing works, make a debug log of you starting the vis and post a zip of it so I can check it out.
