Results 1 to 10 of 11
Thread: RR running lsx void 3.3 and enforcers gas finder help
    Newbie duster's Avatar
    Jan 2009
    I gues this is my first whining post and I hope it is not in the wrong place. Anyways I appreciate the help that is given. I am trying to get the plugin to work inside of my rr. I have the plugin in the plugin directory under rrGas, I added the X,rrgas to the menu.skin. I took the gasconvertor exe and ran it in the lsx void skin directory. I assume this converts the existing gas skin. but to no avail it will not allow me to do anything when I click the gas button. I know it is all on me and I figure it is that I need to add a buton to call the right skin or I need to make a new skin, but my intelligence has failed me and I need a little help. Any help would be appreciated or if someone has a modified skin file to share.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. If you are running one of the lastest versions of RideRunner you do not need to put x,rrgas in the menu.skin if you have put the RRGas folder in the plugins folder.
    2. Make sure you have run the register.bat in the RRGas folder.
    3. you will need to create (or edit) the button that calls the Gas Finder plugin from gas_pricefinder to RRGas.
    Jan 2009
    thanks I will do it on my lunch break, I do need to run the register on my car version for sure and it is the new version and I will try the suggestions . BTW that was a quick reply
    Jan 2009
    well I did what I could but the step 3 is my bane at this moment, I tried inside RR pushing a button for 5 secs and picking empty and it wants a application , I alos looked through the skins and did not see the button (old gas button) listed so I could not modify it. I know this is extremely simple and I should be able to do it, but it is proving annoying. What skin is the one in lsx void that I should modify or am I going about it all wrong. I tried the skin editor but did not see what I needed there. Once again I appreciate the help and apologize for pestering you all.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I don't have the lastest version of LSXVOID, but in the one I have here the commands are in the exectbl.ini
    Have a look in it for gaspricefinder and change it to Gas, Fule Prices, or whatever you want to appear as the button label.
    Then find GAS in the button setups and change that to RRGAS
    you should then be able to do the button press and hold thing.
    Jan 2009
    Thank you very much, it looks as if it will work now it is actually pulling it up, but I do not have internet on it at this exact moment to test till later but that is just a matter of timing, thank you for the knowlege, now to try the rest of your plugins
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I should warn you that the New RRGas plugin has a few extra features that the original didn't, so the LSX Gas screen may have some buttons missing.
    Jan 2009
    well it did not go so well as I hoped, it now pulls up the skin but the reload button did not cause it to refresh or anything so I guess I typed something wrong or something, when I had it map something like a gas station it gave me a line errror of -1 so I guess I will need to do some skinning to get the features you mentioned. other than the lquick info and examples are there any good resources to help configure these and skin, once I get started I am sure I will be fine it is just like programming just need a little jumpstart. again I do appreciate the help and I am extatic that I actually got it to call up the skin it was really annoying me and it was starting to get personal i hate when my toys beat me.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well the line error of -1 is an AutoIT script error.
    hat will be a script that LS has included to pass the GPS coords of the Gas Station to iGuidance. If the GPS coords are not available or you are not running the modified iGuidance then you may get this error.
    Add debug=true to the ini file in the RRGas folder.
    It should produce a debug.txt file, PM me that if you get one.
    Jan 2009
    Well I think you are spot on as I have iguidance and I have not modified it past getting it working to embed in to the RR, I will have to look in to that and I will do the debug thing tonight if still need be.
