Page 12 of 25 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 242
Thread: RRVoiceControl-Beta Complete: Check Released Plugins Section
  1. #111
    May 2007
    woohoo, I got this working using an I-BUS adapter to run the trigger with my "Phone" button on the steering wheel.
    Now, is there a way to dial numbers by voice? I am using the .net Mobile Phone Plugin for RideRunner
  2. #112
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by Toxic0n View Post
    I would assume you at least would be able to call contacts that are stored in your phone book.
  3. #113
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I was thinking on a small script that could look at the phone directory, and add the voice commands into the RRVoiceControl.ini. I then need to see if there is a command for MobilePhone.net to send a number directly to the plugin and have it dialed.
    I am already working a small script, that when you change one of the weather cities at the top of the weather screen in the DFX skin, that will save the city as it does now to the skin.ini, but also save the command into the voice.ini as well. Jebus put lines in the ini to edit it and put your favorite cities, but I want to be able to have the ones that are in the top buttons available, so if you change them, they change for the voice commands as well. This way editing the ini in notepad would not be needed. This will allow commands like "Chicago Weather", "West Palm Beach Weather" ect.....
    @Jebus: Can you add a RR variable that contains the path to the plugin, as I am sure people will put it in different locations... Meaning, I can use something like RR.GetInfo("RRVoiceControlPath).
    My Fiero Build Thread
  4. #114
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Quote Originally Posted by JohnWPB View Post
    It's RRVCPath....
    I'm done with the music number to text conversions, well, there might be something that I missed...
    It is now kickin ***, just have some more debug statements to finish...
    This weekend for testers, unless my testing brings up something....
    ...JJG
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
  5. #115
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Sounds great! Can't wait to test it out!
  6. #116
    Nov 2007
    PA
    I still cant get the muting to work properly. When I hit my trigger button, it's not until AFTER I issue a successful command that it lowers the volume to 1-2%. So if I say "SELECT MENU" it gos to menu and lowers the vol after the command is given.
  7. #117
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Jebus View Post
    [ I will] Probably have something for you to test this coming weekend.
    Hmmm is after 5:00PM today (Friday) considered the weekend?
  8. #118
    Dec 2007
    Washington, USA
    Just got home from work! Give me a bit, I have one more little tweak to the number to text conversion. We'll see if I can get it to ya tonight...
    RRTTS Testing
    RRScript Testing
  9. #119
    Dec 2007
    Washington, USA
    Quote Originally Posted by Dougw133 View Post
    Are you using Master for the volume in RRConfig?
    Do you have ALL the commands in DFX's Exectbl.ini?
    /-------------SerialSwitch-----------------
    "DTRON","SENDMSG;SerialSwitch;DTR_ON"
    "DTROFF","SENDMSG;SerialSwitch;DTR_OFF"
    "RTSON","SENDMSG;SerialSwitch;RTS_ON"
    "RTSOFF","SENDMSG;SerialSwitch;RTS_OFF"
    /"ONDTR_ON",""
    /"ONDTR_OFF",""
    /"ONRTS_ON",""
    /"ONRTS_OFF",""
    /"ONCD_ON",""
    /"ONCD_OFF",""
    /"ONCTS_ON",""
    /"ONCTS_OFF",""
    "ONDSR_ON","SENDMSG;RRVoiceControl;RRVC_ON"
    /"ONDSR_OFF","SENDMSG;RRVoiceControl;RRVC_OFF"
    "QUIT","CLOSEWINDOW;SerialSwitch||ENDIT"
    "ENDIT","QUIT"
    / RR Voice Control
    "ONRRVC_ON","SETIND;!RRVC_Ind;ON"
    "ONRRVC_OFF","SETIND;!RRVC_Ind;OFF"
    "RRVCON","SENDMSG;RRVoiceControl;RRVC_ON"
    "RRVCOFF","SENDMSG;RRVoiceControl;RRVC_OFF"
    "VOL+","VOL+||SENDMSG;RRVoiceControl;RRVC_VOLU ME"
    "VOL-","VOL-||SENDMSG;RRVoiceControl;RRVC_VOLUME"
    /"QUIT","CLOSEWINDOW;RRVoiceControl||ENDVC"
    /"ENDVC","QUIT"
    Do you have ALL these in RRVoiceControl.ini?
    VROnCmd=SETVOL;Master;0
    VROffCmd=SETVOL;Master;
    CurrentVolume=5
    TriggerBeepFreq=2000
    TriggerBeepDur=100
    CommandMatchBeepFreq=1000
    CommandMatchBeepDur=100
    ErrBeepFreq=30
    ErrBeepDur=100
    If so, you might want to wait till I release the new version soon....
    ...JJG
    RRTTS Testing
    RRScript Testing
  10. #120
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Sounds good! I look forward to playing with it tonight if possible, as I do not have to get up at any set time tomorrow I also took the "Listening indicator" a step further when speaking to the system
    When ever you press the button to start voice recognition, a .wav beep sound is played and then that image pop's up on top of RR. When you say a command it recognises, a confirmation .wav is played that sounds VERY similar to the Ford Sync sound, and the pop-up disappears. If you change your mind, you can simply tap the pop-up and it will cancel the voice command, and continue your previously playing audio if any.
    Being that "Listening Indicator" is not a RR menu pop-up, is is fully transparent, and you can also press any of the RR buttons on the screen while it is visible.
