Page 16 of 25 FirstFirst ... 678910111213141516171819202122232425 LastLast
Results 151 to 160 of 242
Thread: RRVoiceControl-Beta Complete: Check Released Plugins Section
  1. #151
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    @Jebus
    One req. When the PI dll is started, set a rr var call RRVCtrlPath with current apps path.
    Ie.. SDK.Execute("SETVAR;RRVCtrlPath;" & App.Path&"\")
    So, that If/when someone(John) wants to modify the apps ini file they can easly find its location.
    Any ETA an the dll PI version beta?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #152
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    @Jebus
    RRVCPath....
    It was in there up to the 11-8-09 build, but in my debugging, I commented it out.
    I just uncommented it, It's in the rr.ini now...
    Hey, how come we can't set a section with SAVETOINI?
    I'm checking everything now...
    I should be able to get a build to John in an hour or so...
    ...JJG
  3. #153
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Thumbs up
    Sounds great! I have been working on adding tons of voice commands in my skin BlueZX3 has also been heavily helping me debug RRvoice, as well as working on updating existing scripts and screens to be more voice friendly.
    Oh, I will be on Yahoo for the next few hours
    My Fiero Build Thread
  4. #154
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    wow from exe to dll can't wait , great work Jebus
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  5. #155
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, it more like the RRMedia setup.... dll controls app.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #156
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    arh
  7. #157
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Jebus, just found a small bug. Instead of explaining it all over again, I have copied my post from the YouTube plugin thread by ElCamino. (I copied it into that thread from my original post in Sonic's Vehicle Maintenance Plugin Thread ) So, as you can see, this little bug has reared its face many times in the past
    Ok, just ran into a slight problem Your plugin. It is preventing sliders in any other extension plugins from working
    You probably just used the old Extension example source code. Quite a few changes were made to help prevent plugins from interfering with each other.
    In your plugin source, in the sliders section, you need to make sure you have this line:
    'This tells RR that the Slider was not processed in this plugin
    ReturnSlider = -1
    You may have something that looks like this if it is older code:
    ReturnSlider = 1000! * Val(Format(Time, "SS"))
  8. #158
    Dec 2007
    Washington, USA
    Well, I am using the latest RR extension Class.
    All the extra that I dont use is commented out..
    Public Function ReturnSlider(SLD As String) As Long
    'ReturnSlider = -1
    Select Case LCase(SLD)
    'Case "myslider"
    'ReturnSlider = 1000! * Val(Format(Time, "SS"))
    'case "myslider2"
    'Insert code here to return your slider value
    End Select
    End Function
    Ahh I see I commented out THE crucial Line...
    I will fix ASAP
    ...JJG
    Edit... Try This...
    Attached Files Attached Files
  9. #159
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yeppers, that fixed it.
    Yea, commenting it out would do the same thing, as when it cycles through the plugin, if it uses a slider or not, it still is not returning what it needs from the plugin.
  10. #160
    Jul 2006
    Hey jebus, how hard would it be to implement a data entry mode? For instance, when you open an osk, voice control would stay active until you said "enter" or "cancel"
