Page 18 of 25 FirstFirst ... 8910111213141516171819202122232425 LastLast
Results 171 to 180 of 242
Thread: RRVoiceControl-Beta Complete: Check Released Plugins Section
  1. #171
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Is that in the last released Beta?
  2. #172
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    yea, build 1.1.0147 or there bouts...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #173
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Don't worry, there's more! I'm on .0274 + now....
    ...JJG
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
  4. #174
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If thats the case....where's my newer beta then...??
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #175
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    My Fiero Build Thread
  6. #176
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mmmmm i think i will join the party lol
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  7. #177
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Need a request...hopefully to make the next beta..
    A setting to what line your getting the vol level from....
    I have changed these two settings:
    DefaultVROnCmd=SETVOL;Master;0
    DefaultVROffCmd=SETVOL;Master;
    To
    DefaultVROnCmd=SETVOL;Wave;0
    DefaultVROffCmd=SETVOL;Wave;
    Which work fine, except that when it set the wave back, it uses the master level.
    So maybe a setting that defaults to the master if setting is not specified...ie 'VolumeLine=xxx' would be 'VolumeLine=wave' in my case.
    The reason that I do this is b/c I'm using a more custom GPS Vol type setup that works the way I want. I control the vol externally, not thru RR.
    Also... I'm surprised that no one else has noticed that if the user is using GPS vol... when you initialize the VC, it sets the master to 0% and then the gps vol resets back to what it should be given the users setting for that feature. This could be done two ways,
    handled internally:
    Get the 'speedatt' setting first, set it to false(off), to the vol change, then on vc done, set the vol back, set the 'speedatt' setting back to previous value.
    via ini:
    DefaultVROnCmd=Setvar;Svd_speedatt;$speedatt$||SET VAR;speedatt;false||SETVOL;Master;0
    DefaultVROffCmd=SETVOL;Master;||Setvar;speedatt;$S vd_speedatt$
    Although, depending on how your doing the off cmd using the settings, would possibly not work if you just append the previous master value to the end of the line, as that value now need to be inserted at the correct spot..
    Thanks,
    I now await for that beta...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #178
    Newbie KARIM1's Avatar
    Aug 2009
    take nop notice of this ;/
    thanks for this great stuff
  9. #179
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    reinstall?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #180
    Dec 2007
    Washington, USA
    Me too...
    It was meant to be user configurable... I'll go back over that part again.
    I've looked at the use of a way to do the attention prompt, and I haven't found a good way to do it yet.
    What I really need is a SET ACTIVESOURCE = OFF/ON command in RR.
    Sort of a VR switch, to allow voice input w/out sound output. And w/out changing anything else in RR.
    Currently ACTIVESOURCE is a Label...
    SETSOURCE is too limited in it's scope to be usefull for this.
    Mute gets outa sync.
    Play/ Pause, ect don't work on every source.
    SETVOL has to take into account a lot of Vars, to work properly.
    SETVOLUME again Restricted for Audio Lines...
    Guino? Mitch?
    ...JJG
    OH ya, I'll try and get something stable out this weekend, after I wake up from the LTrip nap...
    RRTTS Testing
    RRScript Testing
