Page 19 of 25 FirstFirst ... 910111213141516171819202122232425 LastLast
Results 181 to 190 of 242
Thread: RRVoiceControl-Beta Complete: Check Released Plugins Section
  1. #181
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    And here's a little RR screen cap of my "What can I Say" screen in DFX4...
    You can double tap on the selections to test them also...
    An IDL timer in the skin sends you back to LASTSCR after x seconds.
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
  2. #182
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    nice. I like the icons..I simply used elcosmenu to load mine in th indicator section which dims the screens and loads my glow icon..I triied "RRVCON||Say;Please say a command!" But hitting button only mutes audio output so thats not gonna work..lol.. Any suggestions? I'm not sure if this is along the lines you posted ealier. maybe something like
    "SAY;please say a command!||wait;2||RRVCON"
    Did it.. Done it... now I got to keep the neighbors kids away!!
  3. #183
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Jebus View Post
    Me too...
    It was meant to be user configurable... I'll go back over that part again.
    What I really need is a SET ACTIVESOURCE = OFF/ON command in RR.
    Sort of a VR switch, to allow voice input w/out sound output. And w/out changing anything else in RR.
    Currently ACTIVESOURCE is a Label...
    SETSOURCE is too limited in it's scope to be usefull for this.
    Mute gets outa sync.
    Play/ Pause, ect don't work on every source.
    SETVOL has to take into account a lot of Vars, to work properly.
    SETVOLUME again Restricted for Audio Lines...
    Guino? Mitch?
    ...JJG
    OH ya, I'll try and get something stable out this weekend, after I wake up from the LTrip nap...
    As far as the Mute/Play/Pause, you just need to add a small dash of logic and grab the info first .
    Example...
    Code:
    Select Case RR.GetInfo("=$ACTIVESOURCEID$")
      Case 1 To 4
          'Takes care of all radios
          Muted=RR.GetInd("Mute")
          If Not Muted Then RR.Execute("Mute")
          <waits for cmd>
          <cmd matched>
          If Muted Then RR.Execute("Mute")
      Case 5 to 8
          'Takes care of Audio(music),video,DVD
          Status=LCase(RR.GetInfo("STATUS"))
          If Status="play" Then RR.Execute("PAUSE")
          <waits for cmd>
          <cmd matched>
    End Select
    And I personally would like usage of a play/pause if listing to music, too keep from missing it while it waits for a cmd.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #184
    Jun 2008
    Illinoise
    Can I get in on this?
    I dl the 1st post exe, and have been working on full rr integration. Jebus, John, Blue, and Jesse you guys are my heros.
    This is the stuff RR needs to advance to the next level. RR should be the FE that sets the standard.
    I know new beta is in progress now, care to ul to my ftp? -pm me
  5. #185
    Aug 2004
    Germany
    @Blue ZX3: I modified your example a bit, if you don't mind. Hope I got the syntax right:
    Code:
      Case 1 To 4
          <waits for cmd>
          <cmd matched>
          If Muted and RR.GetInd("Mute") then RR.Execute("Mute")  'if user unmuted accidently
      Case 5 to 8
          <waits for cmd>
          <cmd matched>
          If Status="play" and LCase(RR.GetInfo("STATUS"))=="pause" Then RR.Execute("PAUSE") 'if user accidently resumed playback.
    End Select
  6. #186
    Newbie KARIM1's Avatar
    Aug 2009
    ha my mistake iv never updated rr since i installed an i thought id have to reinstall my bad great stuff
    Ok so iv got it workin on its own and recognised all my music , but for the life of me i cant get it to integrate with dfx4 iv writin the lines on first page to the extbl in dfx and iv put the hidden butons in my menu.skin (i hope that was correct) but i cant find the buton also would i be able to use the mute buton ( as my pc is hooked in to a headunit for volume control) as the trigger, if so how would i go about doing this
    thanks for any help
    **edit* ok was my bad as usual i mised out the text :/ john would it be possible to post ur code on getting it to play a wave rather then the beeps pls omg im going on and on but how would i also map it to a buton on my mouse ? iv worked out to use keytbl for keyboard shortcut but im unable to work how to get it on a mouse click ( like i have 4 butons on mouse id like one of them to be the trigger) at the moment iv mapd it to a keyboard buton but is kinda hard havin the keyboard out all the time , im a real 100% noob with all this im not dumb just inexperianced so pls gimme a chance heh
    u guys R what rr needs to be the best keep up the great work
  7. #187
    Newbie Drdee's Avatar
    Jun 2005
    San Diego
    Beta testing and skin-by-skin commands
    Hey Jebus,
    Any chance I can try out yout latest beta? Been working with Version 1.0.0.44 but cannot seem to configure commands on a skin-by-skin basis. Your older version allowed skin-by-skin command selection. Other than that, a wonderful add-on for rideRunner.
    Dawood
    Drdee
  8. #188
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    We are All waiting....
    <-- Goes back to waiting mode....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #189
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    PHP Code:
    Do While
    GetStatus RRVoiceNewRelease
    if RRVoiceNewRelease true then
         Download
      End
    If
      if
    RRVoiceNewRelease False then
         sleep
    (60000)
    End If
    Wend
    My Fiero Build Thread
  10. #190
    Dec 2007
    Washington, USA
    As you both know, DFX4 and RMMedia devs, Good things take time.
    Let's see, it's been a year for both or close to it....
    I'm working on it, many changes internally, less I/O R/W's, = faster response time. It's faster...
    Unfortunately this introduced some timing issues, with RR, currently being worked out.
    I am also looking at other user friendly ways to do the attention sounds, A mute/pause scheme interferes with song loads(playitem) and gets out of sync with RR on screen changes. Lowering the volume is the best scheme I have found.
    All of these changes are being done to eventually create a true DLL plugin, with no external application.
    ...JJG
    RRTTS Testing
    RRScript Testing
