Page 21 of 25 FirstFirst ... 111213141516171819202122232425 LastLast
Results 201 to 210 of 242
Thread: RRVoiceControl-Beta Complete: Check Released Plugins Section
  1. #201
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Blue,
    One note, until the Pause/Resume command works on all sources, RRVoice is using the Master volume for the lowering of volume to 0 to issue a Voice Command and setting it back to the previous level after recognition. If you change this in any way, ie: using SetVol;Wave or any other command change there, then RRVoice will not work properly period...
    It does not keep track of, or touch any other mixer setting at all...
    ...JJG
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
  2. #202
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, that is exaclty what I'm talking about, the controlling the master with no way around it till the next newer better toy... Somewhere in the above posts, is what i have changed those setting to. It does work, it just puts what the master is at instead of what the wave was at...
    Yes, RRMedia release is nearing...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #203
    Dec 2007
    Washington, USA
    Using anything else but MASTER will not work, because if you are on HD Radio or another LINE IN source, you won't be able to silence the source. Using Wave will only silence the wave output for command input. It will be on Master in the plugin till Pause/Resume is fixed for all sources...
    ...JJG
    RRTTS Testing
    RRScript Testing
  4. #204
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not all of us have/want/need radio in our setup, but...
    A little more playing and Poof! Using these two lines/settings, I get EXACTLY what I am after..
    PHP Code:
    VROnCmd
    =RRVolRamper_Dn;100;15;Wave||SETVARBYCODE;STATUS;STATUS||PAUSE
    VROffCmd
    =BYSTR;$STATUS$;PLAY<PLAY>||RRVolRamper_UP||
    Back to being a happy camper!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #205
    Dec 2007
    Washington, USA
    ... Most have/want/need radio, Thats the Dilema, fix for one, break for others...
    VROnCmd=RRVolRamper_Dn;100;15;Wave||SETVARBYCODE;STATUS;STATUS||PAUSE
    VROffCmd
    Thats the beauty of using the INI files for config and leaving this as configurable as possible. A little thought, RRExtended and you are...
    It will work the same with RRVoice.dll, only faster.
    Almost ready...
    ...JJG
    RRTTS Testing
    RRScript Testing
  6. #206
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    PHP Code:
    VROnCmd
    VROffCmd
    Would you mind sharing where you put this code for the pause function to work Blue.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  7. #207
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    those replace the two lines in the RRVoiceControl.ini file, same loc as the exe
    Almost ready...
    Two quick things...
    #1 would be nice/easier if you move the entire vol changing part to the ini where the user as total control of customizing it, if need be...
    ie.
    PHP Code:
    VROnCmd
    =SETVARBYCODE;rrvcsavedvolume;VOL:MASTER||SETVOL;MASTER;0
    VROffCmd
    =SETVOL;MASTER;$rrvcsavedvolume
    #2 <was gonna mention something else,but will wait to see B4 i add comment>
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #208
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Well the pause works great for me but play at VROffCmd does not.
    Any suggestions would be appreciated.
  9. #209
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Do you have RRExt installed????
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #210
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Don't believe I do. I will try that out.
    EDIT: That's what it was. Thanks.
