Page 5 of 25 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 242
Thread: RRVoiceControl-Beta Complete: Check Released Plugins Section
  1. #41
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    This, meaning the program, has worked for me several times in scanning my music though. I too use a secondary hard drive, and my music is arranged in Artist/Album folders the same way I assume you do John.
    D:\My Music\Abba\Abba\Gold\...songs....
    It scanned all 6344 songs on my drive, and never jumped to the C:\ drive. For me the solution was to delete the whole install folder and reinstall, and it started working just fine.
    I do not however have the ability to load an artist and then choose an album. I need to "Load AlbumTitle" from my memory.
    BTW what are you guys using for microphones and momentary inputs to the PC. I know Jebus, you are using a serial type thing, but I dont have a serial connector. Suggestions.
  2. #42
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by drewbp View Post
    using this as a microphone and it works perfectly. I use it with Mobilephone and this voice app and i've never had problems picking up what i'm saying
    and as for my momentary input i'm using one of the buttons on my SpaceNavigator. It sits nicely right in my hand during my drive so its easy to just hit the button and talk.
    Live mp3Car Facebook Chat
  3. #43
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    LOL, I agree stubborness is good, means you know what you want. Thats why I am stubborn. I did not mean anything in a negative way.
    I'm not really discouraged, just knew that I would be spending more time on this than I wanted to right now, if I released it in some form. Summertime, so many hobbies and so little time. It is truly BETA. I do want it to work for all. I'm not giving up. I welcome the input.
    I use HomeSeer also, since 2001, and I believe they are doing the number conversion internally. When you speak the number 1 in an VR event in HS the VR Engine "hears" the word "won" or "one" not "1". They must be doing the logic match internally.
    Sonic, you can minimize it and it will still work, It was meant to be minimized.
    #1 Having only to click the "Hide" menu on the settings form to hide it, should be able to also do the same when using the close window button(top right)
    I will add these features.
    I too have gotten that "Error when rebuilding dynamic list grammar box: -2147220453" message box
    Must be a limitation of the custom control I'm using. I will check it out.
    Make the list of commands a single column instead of mashed together multi columns, most of the bigger commands do not fit in that small column area and run into the list item to the right.
    Again that is the custom control. I will work on that.
    I'd also like to know who else you had test this as you were in the process of creating it?
    Ha! It worked for me, what it doesn't work for you guys!
    Did you try and make one or did you search the web for examples and go from there.
    The latter, after I tried to create my own. I even started down the DB path. Even tried with Sqlite3. I do think that all this belongs in a database.
    drewbp,
    Setting up a touchscreen button/label for this is shown in the first post, although with you changing the volume ini variable, it will not work as intended. Lowering the volume to 0 before speaking and resetting it to previous level after match.
    Don't worry folks, I am going to dissapear for a bit, wrap my head around all this input, and come up with something to test. There is no question in my mind that a GREAT Car PC Frontend has to have voice input. I think it is a matter of driving safety.
    ...JJG
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
  4. #44
    Dec 2007
    Washington, USA
    JohnWPB,
    Is H:\MP3\ a network drive? Or is it an extended partition...
    ...JJG
    RRTTS Testing
    RRScript Testing
  5. #45
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    It is a 4th physical drive on the computer. When I get it all working, it will be on drive E:\ in the car (An external USB hard drive with all the media on it.)
    My Fiero Build Thread
  6. #46
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    I do want to let you know that I really appreciate all the hard work that you have put in to this. I had just tried to use the internal RR voice control recently, and had uninstalled all the microsoft SDK's etc, cause it wouldnt do what I wanted. This has given me something else to play with, I was going to say work on but you are doing all the work.
    Thanks again. I love where it is and look forward to where it is going.
  7. #47
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Jebus View Post
    Second, It is not a plugin. It is a standalone exe. It was not meant to go into RR's plugin folder. It should be able to run from anywhere though.
    Although it is not an "Extension" plugin, it is still a plugin since it is meant to work with RR. So it deserves its own thread in the plugins section and deserves to be listed in any RR plugins list.
    Ride Runner RR's Myspace
  8. #48
    Jun 2007
    St. Louis
    I'm going to try setting this up this evening...this would be SO wicked. Not sure if it does this or CAN do this...but it would put the icing on the cake if you could *speak* the directions to the GPS program of choice.
    Garmin for example, say "Enter Destination" and it activates that portion and you can then proceed speaking the address as is presented on the screen saying "Next" to proceed to the next screen.
    Sounds so much simpler than it is/would be to implement. It's been years since I've done anything in VB6...and I know nothing of Command and Control, but if I could be of any help I'd be glad to pitch in.
    *EDIT* Got it installed and *mostly* setup...I have one problem though...most of my audio files are in m4a format...and this doesn't scan for them. I agree with Bluezx3 that it should simply read the rr.ini to get those defaults to scan for. This way, no matter what format a person's audio files are in, the scanner will pick them up (so long as that person has rr setup for them).
  9. #49
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I assume this works with the actual windows file name and not the ID Tag? I have my entire collection tagged flawlessly, but the file names are another story...
  10. #50
    Sep 2008
    Quote Originally Posted by Dougw133 View Post
    a program called flash renamer can fix that in minutes. it pulls the info from the id3 tags and renames the file
