Results 1 to 5 of 5
Thread: Serial Tachometer
    Mar 2009
    Belgrade, Serbia
    Serial Tachometer
    Is there a way to show RPM based on the input of the serial port?
    I found this project and thought it could maybe be simple to implement it into RR as it is does with Mauri`s voltage and temp readers.
    http://www.hroch.net/sidparal/softwa...cho/index.html
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Either you'll have to make a plugin/application to read the serial port and send the data to RR or make it read from that application and display it in RR.
    Ride Runner RR's Myspace
    Mar 2009
    Belgrade, Serbia
    Guino, unfortunately, I`m out of programming.
    I hope somebody would find useful to read RPM and maybe wright some plugin.
    Sep 2007
    Export, PA
    you can do this a little easier without using up your serial port (can use it for better things, like controlling a Directed HD Tuner w/ mitchjs's cable) by using a fusion brain and FCC's frequency to voltage converter board...
    just a suggestion...
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Probably a lot better since it won't require such an intensive (High CPU load) application running on the PC itself.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Bluetooth Serial Port Nightmare, IOGEAR, Zoom
    By matt621 in forum General Hardware Discussion
    Last Post: 07-05-2008, 08:55 PM
  3. SDK commands over the serial port ????
    By tolisn in forum Road Runner
    Last Post: 12-14-2005, 01:03 PM
  4. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
