Results 1 to 10 of 14
Thread: Visualisation for foobar
    Jun 2007
    I use f2k player plugin in RR
    I have idea to change style vis of foobar by use " foo_vis_shpeck.dll " this is vis plugin winamp for foobar and use " foo_runcmd.dll " to run command
    Step:
    1. install winamp 5.xx. I test with 5.22,5.24
    2. install foobar components
    3. add shpeck in ui foobar without shpeck titlebar
    4. in foobar shoose autostart plugin shpeck(AVS) and don't select stop when hidden
    5. open rrconfig musicsetup page2 changename vis from foobarvis to AVS set transparents vis if you want
    6.edit command on your skin to run AVS
    I use this command to run avs in RR
    "LOAD;audio_visuals.skin||VISU||run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'""
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I definitely have to give you credit for researching this stuff on your own.
    Ride Runner RR's Myspace
    Jun 2007
    Thank you
    Now In this case .. I can not complete to close avs...when I close vis page the avs window running on background ( "VISU||EXIT" )
    when I stop by foobar cmd and run vis page again avs not appear ?? I dont understand.
    "VISU||EXIT||run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="View/Visualisations/Shpeck - Stop"""
    guino's Avatar
    Nov 2004
    Toronto, Canada
    When using the vis with the foo_runcmd.dll (your way described here), I would suggest you to not use the VISU command and instead did this:
    To Start Visu:
    Code:
    "LOAD;audio_visuals.skin||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'";$visuname$"
    To Stop Visu:
    Code:
    "EXIT||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Stop""
    Jun 2007
    I test your newest option plugin vis for foobar
    its work very well..
    Newbie qazaq9's Avatar
    Apr 2009
    im trying to do the same things and i can't get it to work. like "anuchit" said on #5
    "5. open rrconfig musicsetup page2 changename vis from foobarvis to AVS set transparents vis if you want"
    after i do that and run rr, it changes back to "foobarvis" from AVS
    also, inside the skin when i assign a string to a button as described above by using "foo_runcmd.dll" it runs visualization but the foobar's default "Spectrum"
    and when i execute command to exit vis, i get an error message:
    "unknown commandline parameter: /runcmd=View/Visualisations/Shpeck - Stop"
    I also tried to use command for the button as "anuchit" initially listed and it returned with an error:
    "unknown commandline parameter: /runcmd=View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'"
    Any suggestions?
    Specs:
    win XP-pro
    RR 03/02/2010
    winamp 5.572
    foobar 0.9.6.9
    foo comserver2 0.7
    foo vis shpeck 0.3.7
    Jun 2007
    Oh no qazaq9
    That i create myself not good
    Please go to foobar player plugin this option create new vis option by Guino..Its work ..
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I try to do the same thing, but i have not the same screen:
    I have that and i don't know why:
    and i should like that :
    If i change the visuname from FoobarVis to AVS, that don't run for me!
    this command run well the visu but not that i want:
    Code:
    B,2,427,073,27,"LOAD;audio_playerCWD.skin||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'";$visuname$",
    this command run well the exit command but don't exit from the foobar visu:
    Code:
    B,1,460,073,27,"EXIT||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Stop"",
    Is my shpeck settings good ?
    Jun 2007
    Please read step by step by Guino on the first page
    Foobar2000 Player Plugin
    and see my guide picture
    This is spectrum analyzer that u like...
    Attached Files Attached Files
    May 2008
    Bordeaux, France
    Smile
    All run very well for me.
    Where do you put the avs files ?
    That i don't know is that i must to push on the shift+alt+v to run the avs .
    Also i have make an autoit script that do it for me.
    But i don't know how to do shift+alt+v in autoit.
    Also i modified shift+alt+v by Alt+F1 , i upload my little job (you must to change the key short in foobar).
    and my command is:
    Code:
    B,2,427,073,27,"LOAD;audio_playerCWD.skin||run;C:\Program Files\foobar2000\foobar2000.exe|/runcmd="View/Visualisations/Shpeck - Start 'Advanced Visualization Studio v2.81b / Advanced Visualization Studio'";$visuname$||run;$skinpath$Scripts\RunAvsFoobar.exe",
  1. Winamp Visualisation
    By nashakontora in forum Road Runner
    Last Post: 11-23-2007, 05:39 PM
  2. embedding visualisation
    By holistic in forum Road Runner
    Last Post: 02-17-2005, 02:20 PM
  3. For the visualisation problems into the V1.9
    By coyote in forum MediaCar
    Last Post: 03-04-2004, 05:05 PM
  4. Mediacar and visualisation
    By jim22 in forum MediaCar
    Last Post: 03-01-2004, 06:14 AM
  5. Future Visualisation Support?
    By Jamez_Warner in forum MediaCar
    Last Post: 01-02-2004, 01:39 PM
