Results 1 to 5 of 5
Thread: SDK.GETINFO to get indicator values
    lambosprit's Avatar
    Sep 2006
    UK
    Is it possible to use sdk.getinfo to retrieve indicator values? I thought it was but not having any luck. I can only get label data back.
    Specifically I'm trying to test if a plugin is running (gpslockout) and if it is whether the lockout is engaged but can't figure out how.
    May 2007
    For indicators you can use SDK.getind instead of SDK.getinfo.
    lambosprit's Avatar
    Sep 2006
    UK
    thanks for that but when I try it I get a subscript out of range error.
    My code is RR_GetInd = sdk.GetInd("GPSLOCKOUT", "menu.skin")
    not sure I need the menu.skin bit.
    Any ideas what I'm doing wrong now?
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    no need for the menu.skin, also be sure that RR is fully loaded before trying to access the sdk, sometimes if you try to get some info to soon it wont work. try using "ONSKINSTART" for testing.
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by EL CAMINO View Post
    cheers EL CAMINO that was exactly it. Trying to put debug in too soon. All working now.
