Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Skin commands to control USB relay
  1. #11
    MySQL Error
    Oct 2004
    prob a handy ONSourceChange could be added
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Mar 2007
    Nashua, NH
    Well, the ONRESUME command was doing nothing at all. It wasn't until I set hibernateaware=false. Then the ONRESUME command began working.
    But now, I do not get audio from the HD or XM radios upon resume. If I restart RR, then it works fine. But lose audio upon the next resume. MP3s work fine.
    But, the antenna up/down works fine now! That onresume command works.
    EDIT: Should have mentioned that I can communicate with the HD or XM radios via the serial link. I get the name of the artist or signal strength (in XM). Just no audio.
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    very odd... the ONRESUME command should always work but the hibernateaware should be true for most cases. Just make sure you're not using forcehibernate or something like that... how are you hibernating anyway ?
    Ride Runner RR's Myspace
  4. #14
    Mar 2007
    Nashua, NH
    Actually, I'm not hibernating. I am suspending and resuming. (S3 to S5).
    I actually used RRConfig, so I am not sure what ini settings it changed. I will check to be sure.
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 12:23 PM
  2. The WinXPe Colab Installation instructions
    By darkslyde in forum WinNT Based
    Last Post: 02-17-2008, 05:59 PM
  3. USB Controlled Relay Board or general output
    By 2k1Toaster in forum Hardware Development
    Last Post: 05-29-2007, 11:40 AM
  4. TO ALL SKINNERS (read this)
    By jeep642 in forum Road Runner
    Last Post: 05-01-2007, 11:23 AM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
