Results 1 to 10 of 14
Thread: Skin commands to control USB relay
    Mar 2007
    Nashua, NH
    I am using RR from 01-01-10 and am trying to figure out how to control a USB relay when I select HD Radio and when the audio source changes to something other than HDRadio. The relay board will control the power antenna. I want it to extend only when HD Radio is selected.
    I have looked for a skin how-to and can't find it. I have done a number of searches in these forums and found nothing applilcable.
    Can someone give me some insight on how to execute an external command to control the relay?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Do you have an external board or anything like that to control the relay ? how do you have the relay hooked up ?
    At the least you're going to need the SerialSwitch plugin with the relay hooked up to the serial port (output pin) -- probably using a transistor+resistor at the least.
    Ride Runner RR's Myspace
    Mar 2007
    Nashua, NH
    It is a board that has a USB interface that appears to the computer as a serial port. I already wrote a small util to open the serial port and turn the realy on or off. I just want to know how to call the program I wrote when I select HD Radio and then again when the audio source changes.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You already did the hardest part.. you just need to use the RUNQ command to execute your application when going in/out of the screen.. simplest way is to edit the .skin files:
    in menu.skin -- change "RADIO" for "RUNQ;c:\myapp\antennaup.exe||RADIO"
    in radio_player.skin -- change "EXIT" for "EXIT||RUNQ;c:\myapp\antennadown.exe"
    Alternatively, you can put the antenna down command on the buttons for the audio/video in menu.skin so that it only lowers the antenna when you switch the source of audio.
    Mar 2007
    Nashua, NH
    Great...that's what I needed!! Thanks!
    Mar 2007
    Nashua, NH
    Hmmm...one more problem. When I go to radio (antenna goes up...yea!), back to main menu, then go to video (antenna goes down), when I stop the video it automatically goes back to radio, but the antenna up command is not executed again.
    Any thoughts?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    yes, that's a typical thing using the resume feature.
    Try adding the following to your exectbl.ini (replace with your command):
    "ONSCREENCHANGE","RUNQ;c:\myapp\antennaup.exe" ,fm
    be sure to remove the "antennaup" command from the RADIO button (as it should no longer be needed). You may want to put a check on your app so it doesn't try to raise the antenna when it's already "up".
    Mar 2007
    Nashua, NH
    Quote Originally Posted by guino View Post
    Is there a place to find a reference for these commands? The above command works great for putting the antenna back up when resuming the radio. But when the system comes out of standby and the radio was the last source (so it continues as the computer wakes up), the antenna doesn't go up.
    I am guessing there's an ONRESUME command. Any chance of that? Would the text be the same? i.e.:
    "ONRESUME","RUNQ;c:\myapp\antennaup.exe",fm
    Thanks for the help Guino!!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you can try exactly what you posted:
    in any case, the events "ONxxxxx" are listed on exectbl.ini and everything else is described in Skin commands.txt (Docs folder).
    MySQL Error
    Oct 2004
    but that would put the antenna up, even if radio not the ACTIVESOURCE
    i think a BYVAR;ACTIVESOURCEID
    is your key
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  2. The WinXPe Colab Installation instructions
    By darkslyde in forum WinNT Based
    Last Post: 02-17-2008, 06:59 PM
  3. USB Controlled Relay Board or general output
    By 2k1Toaster in forum Hardware Development
    Last Post: 05-29-2007, 12:40 PM
  4. TO ALL SKINNERS (read this)
    By jeep642 in forum Road Runner
    Last Post: 05-01-2007, 12:23 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
