dont use ReturnIndicator, dont even have the function!
just ReturnIndicatorEx
on another note... i hope you generated your OWN GUIDS for the interface and class
if you want some direct help... pm me
Hey!
I'm trying to get a couple of images to be displayed from my C# plugin.
I was able to display an image from my skin file using 'IMG', but when I try to use an indicator things don't work. I'm trying to use the same image in both methods.
Some background... This plugin is a custom sirius plugin for my OEM sirius receiver. I'm trying to show the current sirius channel art. I can debug my plugin, and I can see that my custom indicator is getting called, as is the albumart indicator.
Here is some example code:
skin file:
plugin.csCode:I01,543,7,242,92,$RTGCANBUS_SIRIUS_FAV01$ J01,543,7,242,92 /IMG,543,7,242,92,"C:\Program Files (x86)\RideRunner\SRArt\20.png"
So... what am I doing wrong.... I have tried all of these options separately by commenting them out in both the skin file and the plugin.Code:public string ReturnIndicator(string Ind) { string s = ""; return s; } public string ReturnIndicatorEx(string Ind) { string s = ""; if ((initd) && (active)) { switch (Ind.ToLower()) { case "rtgcanbus_sirius_art": s = "C:/Program Files (x86)/RideRunner/SRArt/" + currentSiriusChannel.ToString() + ".png"; break; case "rtgcanbus_sirius_fav01": s = "C:/Program Files (x86)/RideRunner/SRArt/20.png"; break; case "albumart": s = "C:/Program Files (x86)/RideRunner/SRArt/20.png"; break; } } return s; }
Thanks,
Ryan
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Hey Mitch....
I can't instatiate the sdk class without ReturnIndicator... using the sample c# plugin.. I'll try removing it from the sdk....
and....
I am generating my own GUIDs...
Ryan
you are right.... that isnt your problem anyway
its been a while since i did one
anyway...plugins are easily debugged
albumart is a special indicator... you going to override it or any indicator
you need to if active clear the IND
case "albumart":
Ind= "";
break;
since when exiting the plugin, the rr core will sill process the indicator as normal
and albumart in and of itself is a tricky indicator, that switches its function depending on active source
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
also
this doesnt look right
maybe
I01,543,7,242,92,"RTGCANBUS_SIRIUS_FAV01"
you KNOW SKIN TOOL IS YOUR BEST FRIEND
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
The quotes are what made it work....
I didn't realize that my custom indicators needed to be surrounded with quotes... Is there a good FAQ that includes this kind of info?
Also.... SkinTool..... WOW! I didn't even realize that tool existed... It is awesome.
On a separate note, how do I make RR work such that I can enable my custom Sirius plugin's audio and corresponding information (channel, channel name, track name, etc.) to be heard and seen, and then when I switch to HD Radio or mp3 audio that those get disabled and the right audio and info is enabled.
So I'm listening to my Sirius, then want to listen to HD Radio, so I click on the Radio button. When this happens, I want RR to automatically mute the Sirius, unmute the HD Radio, and only display info from the HD Radio. Going from mp3 audio to HD Radio and back all works correctly in the skins I've tried (LSX Void & Digital FX)...
I have a workaround in place now, but I don't think it is the right way to do it....
Thanks for everything so far! It has helped a bunch!
Ryan
