Results 1 to 3 of 3
Thread: RadioMute indicator
    lambosprit's Avatar
    Sep 2006
    UK
    RadioMute indicator
    Is there a way to detect whether the radio is muted or not? I'm trying to mute the radio during a phone call and then decide whether to unmute or not but can't work out how to detect the original setting. I tried just unmuting but that isn't good if you do want the radio muted. Doesn't seem to be anything in either the skin commands or radio commands files
    thanks for any help
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Currently the Radio mute feature is limited to commands -- mostly because some radio cards won't even support the mute function.
    The only suggestion I can make is to keep track of the Mute state using a variable toggled with the Mute button of the radio (during normal operation), then check that state to see if you should unmute after the call is over.
    If you're using this on an extension plugin, then you can track the radiomute commands to see when/if they are executed, and keep that last state so you know what to do after the call is over.
    Ride Runner RR's Myspace
    lambosprit's Avatar
    Sep 2006
    UK
    Thanks. Sounds like the best way of doing it for now.
  1. Replies: 60
    Last Post: 06-26-2010, 01:38 PM
  2. bluetooth woes
    By gentoocar in forum Linux
    Last Post: 12-12-2009, 03:05 PM
  3. GPS/Radio/music/DVD active indicator
    By Lucifer in forum RR Skins
    Last Post: 07-21-2008, 06:17 PM
  4. GPS Status indicator?
    By JohnWPB in forum Road Runner
    Last Post: 01-08-2008, 10:09 PM
  5. Indicator Within button border problem
    By JohnWPB in forum RR Bug Tracker
    Last Post: 08-15-2006, 12:48 PM
