View Poll Results: Do you think you will use it?
Voters
9. You may not vote on this poll
  • yes
    8 88.89%
  • no
    1 11.11%
Results 21 to 30 of 33
Thread: RRTranslator
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by EL CAMINO View Post
    just from an Ext. PI.
    define an event, then use your ExecTBL, or just execute what you need from the PI.
    Ok , thanks el camino. I have called a new feature like that for the new RR release .
    If it is not possible, i shall create one little dll for translator that do that.
  2. #22
    May 2008
    Bordeaux, France
    Smile New update
    A new update is on the first post .
    You can in the v0.4 version:
    -To use it on XP and Vista
    -To choose the language to translate (en=english, fr=french, ...)
    -To choose the final language (fr=french, en=english, ...)
    -To choose if you want to use your own dictionnary or google
    -To create your own dictionnary
    -To add or not each search into your own dictionary
    -Click on Indicators (translator or money) for change from translator.skin to convertissor.skin (use translator.dll)
    (Please make a RRTranslator folder under your Plugins folder, copy the dll into and register it).
    I work on another features:
    -money translation
    -measure translation
    -units translation
    Buttons and screen exist but not fully functional .
    Good use :-)
  3. #23
    Oct 2009
    Great Pier!
    Now it works :-)
    thank you.
  4. #24
    May 2008
    Bordeaux, France
    Quote Originally Posted by fepra View Post
    Great Pier!
    Now it works :-)
    thank you.
    I am happy to ear that !
  5. #25
    May 2008
    Bordeaux, France
    Smile Need help around the choice.skin screen
    Actually, i have several choice menu to choose the languages (from and to) and the dictionary:
    -ChoiceFrom.skin
    -ChoiceTo.skin
    -ChoiceDictionary.skin
    choicefrom.skin:
    Code:
    RoadRunner Skin
    RRScreen Choice Menu
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,16,16,225,46,255,128,0,22,"Arial:b","=$MESSAGE$","center",,"DS=2,2,0,0,0"
    B,242,114,59,72,"SENDMSG;Translator;LANGUAGEFROM||LANGUAGEFROM",
    B,242,218,59,72,"DOWNPIC",
    B,242,13,59,72,"UPPIC",
    B,16,69,220,221,"ESC",
    /,List and sliders
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S,524,24,41,259,524,24,41,259,V,0,"mixersliderH.png",20,"CLSLIDER",
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
    IL,CL,transparent.bmp,sel.bmp,end.bmp,0,50,60
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    SC,305,16,212,276,255,255,255,0,0,0,0,0,0,255,255,255,true,25,"Lucida Sans Unicode"
     /, I, x, y, w, h, Code;INDICATORCODES
    I,34,85,187,118,"FILE;$Skinpath$Scripts\Translator\Flags\$imagefrom$"
    /, IL, LIST, SELIMG, UNSELIMG, ENDIMG, LIMITMODE, DRAG, MAXSPEED
    IL,CL,TRANSPARENT.BMP,SEL.BMP,END.BMP,0,20,70
    END
    and the exectbl.ini for the choicefrom.skin:
    Code:
    /***************************************TRANSLATOR****************************************
    "TRANSLATEFROM","CLCLEAR;ALL||MENU;CHOICEFROM.skin||CLLOAD;$SKINPATH$Scripts\Translator\LANGUAGES.txt;TRUE||UPDATE_PIC||SETLIST;2"
    "LANGUAGEFROM","SETVARBYCODE;LANGUAGEFROM;LISTTEXT||SETVAR;LANGUAGEFROM;$LANGUAGEFROM$||SAVETOSKIN;LANGUAGEFROM;$LANGUAGEFROM$||SAVETOSKIN;IMAGEFROM;$IMAGEFROM$||WAIT;0.5||EXIT"
    "ONCLCLICK","UPDATE_PIC",CHOICEFROM.skin
    "UPDATE_PIC","SETVARBYCODE;IMAGEFROM;CLDESC||SETVAR;IMAGEFROM;$IMAGEFROM$.gif",CHOICEFROM.skin
    "UPPIC","UP||UPDATE_PIC"
    "DOWNPIC","DOWN||UPDATE_PIC"
    That i should like is to have only one screen (choice.skin).
    I have modified my screen like that:
    Code:
    RoadRunner Skin
    B,242,114,59,72,"SENDMSG;Translator;$CHOICEOK$||$CHOICEOK$",
    B,15,69,220,205,"ESC",
    /,List and sliders
    I,34,85,187,118,"FILE;$Skinpath$Scripts\Translator\$folder$\$image$"
    END
    and the exectbl.ini like that:
    Code:
    "TRANSLATEFROM","CLCLEAR;ALL||MENU;CHOICE.skin||CLLOAD;$SKINPATH$Scripts\Translator\LANGUAGES.txt;TRUE||UPDATE_PIC||SETLIST;2"
    "ONCLCLICK","UPDATE_PIC",CHOICE.skin
    "UPDATE_PIC","SETVARBYCODE;IMAGEFROM;CLDESC||SETVAR;IMAGEFROM;$IMAGEFROM$.gif",CHOICE.skin
    I can to obtain that with my autoit script that configure the variables for the good choice screen:
    If i want to configure for a compatible choicefrom.skin, the script send that:
    Code:
    $rr.execute("SETVAR;CHOICEOK;LANGUAGEFROM||SETVAR;FOLDER;FLAGS||SETVAR;IMAGE;IMAGEFROM||SETVAR;CHOICECANCEL;ESC")
    $rr.execute("menu;choice.skin||SETVAR;MESSAGE;Translate From||TRANSLATEFROM")
    You see that :
    $CHOICEOK$ replace LANGUAGEFROM or LANGUAGETO or CHANGEDICTIONARY
    $folder$ replace Flags
    $image$ replace imagefrom or imageto or dictionary
    The screen run very well, settings are well saved but i don't see the good images into the screen.
    Some body can explain me please where is my error ?
    May 2008
    Bordeaux, France
    Smile New feature
    These is two new feature for the translator.
    Convertissor for money or units:
    As soon as possible
  7. #27
    May 2008
    Bordeaux, France
    I have found how to replace the two choice menu by one.
    I hev replaced these lines:
    Code:
    by:
    Code:
    $rr.execute("SETVAR;CHOICEOK;LANGUAGEFROM||SETVAR;FOLDER;FLAGS||SETVAR;IMAGE;$IMAGEFROM$||SETVAR;CHOICECANCEL;ESC")
    But i have always an issue in the choice.skin screen, my .png files (flags) are not updated each time i choose another language.
    An idea please ?
  8. #28
    May 2008
    Bordeaux, France
    Smile Update
    Hello guys,
    A little update for a compatibility with Gmail Notifier .
    First post is updated
  9. #29
    May 2008
    Bordeaux, France
    Smile
    Little update (v06)
    -Now just one process can be launched in same time.
    Note:
    you can also to Install Translator under your Plugins folder:
    Plugins\Translator\...
  10. #30
    May 2008
    Bordeaux, France
    Smile
    See first post for a little update !
