The IDEAL solution would be to only execute "MYPLUGIN_CMD" and have your plugin execute BOTH: "SETVAR;MYPLUGINVAR1;prog.exe||RUN;$MYPLUGINVA R1$" -- in the case of RUN, your plugin could just launch the application already. If you want "MYPLUGIN_CMD" to have the option between setting the var and then run OR just set the var, then you can make a parameter for it.
Another alternative (less Ideal) would be to use a delay:
"MYPLUGIN_CMD;data1||DELAYEXEC;1;RUN;$MYPLUGINVAR1 $"
LinkBack URL
About LinkBacks
